Coil Shorting out ?
Old Mar 12, 2003 | 06:35 PM
AUBronco40's Avatar
AUBronco40
Question Coil Shorting out ?
ok for the past day or 2 I have noticed a ticking sound while in idle...I couldn't hear it while I was driving but it may still be happening... so i went to check it out and i open the hood with the engine running and there is a spark shooting out of the coil wire...
Its not shooting to anything metal, it looks like it is jumping to itself or a rubber hose that was running alongside of it.
What causes this?
Will getting a new wire fix it?
There was some corrosion under the wire.
Also could this cause any kind of rough idle or slipping while driving because the engine mis-fires or something, or do I have something wrong with my trans too.
So what do I do? Sorry for the long one...Any help will be greatly appreciated.
Old Mar 12, 2003 | 07:06 PM
sparky's Avatar
sparky
Coil Shorting out ?
Insulation probably is cracked....new set of wires should cure the problem...should replace the set because if one is breaking down they probably all are close.....and yes it could cause a miss
Old Mar 12, 2003 | 09:42 PM
deano512's Avatar
deano512
Coil Shorting out ?
Something like this happened to me also.
turns out the center spring loaded button on the inside of the distrubutor cap had burned through the metal tab on the rotor and, of course, the wires were bad...and at night (especially if it was damp out) it looked pretty scary under the hood.
good luck
deano
RANGER589
Electrical Systems/Wiring
Jun 25, 2014 09:09 AM
F-250 restorer
Nov 12, 2013 06:47 AM
tristopher1234
1997 - 2003 F150
Jul 19, 2010 01:47 AM
I'minthegarage
Mar 23, 2009 01:39 PM
misty24
May 26, 2005 11:34 PM
