1978 - 1996 Big Bronco
Brake Issues
Old Feb 21, 2011 | 10:52 AM
USAFCrewChief's Avatar
USAFCrewChief
Exclamation Brake Issues
Alrighty, so i bought my bronco about a week ago, and had noticed that it felt like the brakes were dragging. I found out why when i too a look at the drivers side front. It looks like the pad was on crooked or something. Not only is the surface of the rotor all scratched/gouged/whatever but it looks like the shoulder down towards the wheel studs has been being rubbed on by the pad causing it to be gouged as well. Soooooo, i put new pads on without a new rotor or getting it turned and still the same dragging, maybe even worse.(i know that isn't the smartest thing but money is a little tight right now, and i also wasn't sure of the right way to take out the wheel bearings to even remove the damn thing). I'm pretty sure i put the pads on correctly, it seemed like the only way they could go. Could it be a problem with the caliper? or are the grooves in the worn rotor possibly pulling the pad down onto the shoulder? HELP! Its an 84 XLT
Old Feb 21, 2011 | 01:27 PM
USAFCrewChief
Ok new question, when I'm taking off the rotor/hub does the bearing need to come out or just the locker before the rotor/hub can be taken off of the spindle?
Old Feb 21, 2011 | 04:34 PM
Encho's Avatar
Encho
The Southernmost Mod
You should try posting your question in this section of the forum: 1987 - 1996 F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums usually there are more folks there and since the trucks share so much in common they'll be able to help you, good luck.
Old Feb 21, 2011 | 05:40 PM
USAFCrewChief
Ah that would've been a good idea. i ended up figuring out by just guessing haha probably not the smartest thing, but i needed to drive it to work tomorrow. Next time i will use that section for parts that are in common, for maybe a quicker response. Thanks! and man im jealous, i bet there is some great places to go in S. America in a 4x4!
Old Feb 21, 2011 | 06:01 PM
Encho's Avatar
Encho
I'm glad to hear (read) that. You can check my gallery, there are some old pics of some of the trips i've taken.
