Sponsored by: Real Truck
Trailer brake system question
Old Feb 20, 2011 | 07:16 PM
WorkhorseF250's Avatar
WorkhorseF250
2006 F-250 5.4l V8 XLT super cab 4x4
Question: the truck never came with the trailer brake from the factory and i would like to get the OEM trailer brake system done on my rig, i have the controller for in the cab just need to know the brake booster? on the vin for ford fleet it says its standard. what brake booster would i need?
thanks in advance
Reg.
Old Feb 20, 2011 | 11:03 PM
TexasRebel's Avatar
TexasRebel
you don't have to change the booster.
you have to change the master cylinder and get the pickup programmed to know it has the TBC.
Old Jan 4, 2015 | 12:11 AM
Tripodme's Avatar
Tripodme
Brake Controller upgrade (OEM)
thanks in advance
Reg.
Hi, i have the same truck, what did you do (if you ever did) to get the OEM brake controller installed on your rig ?
Old Jan 4, 2015 | 10:30 AM
moymurfs's Avatar
moymurfs
I'm in the same boat. After lots of checking, it's just plain easier, cheaper etc to get an aftermarket electric controller and ready made harness that makes the whole thing almost plug and play. Granted, you don't get the factory look but the function and end result is the same,,just cheaper. The factory control unit only does electric brakes also..not hydraulic.
Wassup599
Sep 6, 2016 10:37 AM
F-250 WARHORSE
15
Aug 9, 2016 09:51 PM
Redagain
Aug 29, 2015 10:58 PM
Six Niner
Jan 25, 2008 06:09 AM
66gpw
Aug 2, 2005 09:49 PM
