1977 F150 Low Side Service Port?
Old Feb 20, 2011 | 05:03 PM
Customlover's Avatar
Customlover
Hey guys I was wondering if anyone could tell me where my low side service port is in my 1977 Ford F150. It has a 400 in it and I bought the retro fit valves to convert to r-134a with. I believe it to be located on my compressor but I want to make sure. Thanks a lot.
Old Feb 24, 2011 | 03:11 PM
jsutton's Avatar
jsutton
It's on the fitting that attaches to the compressor, and there is a valve on the end of the fitting that has to be opened too after you hook up the gauge set. But there is a lot more to converting to R-134a than just putting those fittings on and sticking a few of cans of cheap r134 in it. It may work for a while but I doubt for very long.
I converted mine to R-134 last year and I bought new fittings, new hoses, new drier (a must), new expansion valve, and new o-rings(also a must), used condenser. The only things original in my A/C system are the York compressor and the factory evaporator core.
Here is pic to answer your question though.
Old Feb 26, 2011 | 11:19 AM
lsrx101's Avatar
lsrx101
Also make sure you understand how those valves work.
-Back seated (full out counter clockwise)- Normal operation. Service ports are sealed off from the system.
-Mid seated (half way between full in and full out) Service position. The service valves are open to the system.
-Front seated. (Fully in, clockwise) Isolates the compressor from the rest of the system. NEVER front seat the valves with the system running. There are exceptions, but not in a normal DIY situation.
There is a square drive ratchet wrench made to operate those valves and it's cheap. Please resist the temptation to use an open end wrench or adjustable wrench on them.
Unlike a modern system, your compressor has an oil sump like a small engine. The oil needs to be drained, flushed and new oil poured in. The aerosol can of oil in the kit won't work.
Like jsutton said, there's a lot more to an R134a conversion than installing a Death Kit. Do some research first:
Automotive AC Information Forum - ACKITS.COM
Old Apr 21, 2012 | 03:36 PM
nehuge's Avatar
nehuge
Two questions:
1) So when I open up these valves midway, I leave them open while I'm adding a can of freon?
2) What's happening during the freon going in is there is a high pitched squeal almost like some pressure releasing, then the blower in the dash stops and the compressor stops.
If I turn off the truck and wait 2 minutes, I can fire it back up, the a/c switch on the dash makes the blower spin up, air blows, then again 5 minutes later t here is this squeal and hiss and the compressor stops and the blower stops. Any ideas?
Old Apr 22, 2012 | 04:33 AM
critterf1's Avatar
critterf1
Sounds like a blockage. What does the high side pressure look like?
Old May 20, 2012 | 10:57 PM
Rusty_S's Avatar
Rusty_S
Why wont the aerosol can of oil not work? Even though the york compressors like mine has a sump they are all interconnected with the refrigerant system. Even if you were to use the oil check opening to fill your compressor with the correct amount of oil on the initial start up the compressor will pump the oil out of the crank case into the system and within a few minutes the sump will get most of the oil back and there it will stay.
personally since I was installing a new compressor I poured the right abount of oil into the suction port then capped it off till I was able to get it bolted in and hook the lines up.
But I am curious why though you said the aerosol cans of oil will not work.
Old May 20, 2012 | 11:24 PM
lsrx101's Avatar
lsrx101
personally since I was installing a new compressor I poured the right abount of oil into the suction port then capped it off till I was able to get it bolted in and hook the lines up. Also, if you drain the compressor and add aerosol oil, the compressor will run dry.
With a sump type compressor, like your York, very little of the oil flows through the system. Most of it remains in the crank case to lube the compressor. Oil out in the system is much like "blowby" in an engine.
With modern (post 1978 or so) systems, there IS no crank case, so the oil HAS to circulate or the compressor starves.
With the aerosol cans and a sump type compressor, the 2 incompatible oil types mix over time and form something like tar that really do a number on the whole system.
Old May 20, 2012 | 11:28 PM
Rusty_S's Avatar
Rusty_S
I dont mean mixing oil types. I took it as you saying the aerosol cans of oil is no good at all. I dont exactly agree with that considering the design of the York compressor.
I know mixing oil types can cause all kinds of trouble, but I never seen any problems with using aerosol oil cans on the york compressors. The oil will find its way back to the sump in the york even if its in the line. It just would be nice if you could still find the dipsticks to check the oil level. But Ford says if the system is working fine theres no reason to check the oil level.
Old May 21, 2012 | 12:06 AM
lsrx101's Avatar
lsrx101
I fixed my previous post as you were typing.
A dry, sump type compressor would starve and be damaged before the aerosol oil accumulated in the crankcase to lube it.
Aerosol oil is made for post 1978 systems with no oil sump. Most systems in recent (retail) memory are sumpless.
A dipstick is easy to make. I don't remember how offhand, but the info is widely available online.
jackietreehorn
Jul 26, 2017 06:58 AM
Bigbluedent1977
Aug 21, 2016 07:55 PM
Lowered IQ
18
Feb 20, 2014 11:28 PM
dafella
Jul 12, 2011 06:25 AM
F250reddog
Mar 23, 2004 09:16 AM
