Truck dying
Old Feb 20, 2011 | 02:25 PM
ralphy_2002us's Avatar
ralphy_2002us
Truck dying
I would be going down the road and all of sudden my truck dies. I try 3 or 4 times to crank it and then it will start right up. Has done it to me bout 4 times over the past 2 days. Has anyone had this problem before?
Old Feb 20, 2011 | 02:30 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
That sounds like your CPS(cam position sensor).
Old Feb 20, 2011 | 02:32 PM
ralphy_2002us
I changed that out like a month ago.
Old Feb 20, 2011 | 02:33 PM
ralphy_2002us
Also I have 2 brand new batteries but my battery light will flicker every so often. I don't know if that has anything to do with it. But it has been doing that for weeks but my truck just started dying yesterday.
Old Feb 20, 2011 | 02:39 PM
megawatt00's Avatar
megawatt00
Where did you get the CPS from? Some of them have been know to fail right out of the box. Your battery light may be flickering because the connector on the top of the alt is loose. That is what happened to mine.
Old Feb 20, 2011 | 02:43 PM
ralphy_2002us
I got the CPS from the ford dealership. I got it bout a month ago and only been driving the truck for the last week.
Old Feb 20, 2011 | 02:53 PM
big poppa's Avatar
big poppa
Is your truck chipped or do you have a CB in your truck??
Old Feb 20, 2011 | 02:57 PM
ralphy_2002us
Everything is all stock. No cb.
Old Feb 20, 2011 | 03:11 PM
bulla's Avatar
bulla
Like you turn the key off or does it stumble down?
Old Feb 20, 2011 | 03:13 PM
ralphy_2002us
It dies completely. I put it in park and try to crank
It up and usually starts after the third are fourth time.
Old Feb 20, 2011 | 03:46 PM
ralphy_2002us
Oh and I forgot. When it is ideling it has just shut off before. But it starts right back up. It has done that like 3 times in the past month.
Old Feb 20, 2011 | 03:57 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Check the tin nut on the IPR, just thinking out loud
Old Feb 20, 2011 | 04:08 PM
ralphy_2002us
What is that and where is it located?
Old Feb 20, 2011 | 04:13 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
It is the injector pressure regulator and it is on the back side of the fuel bowl
Old Feb 20, 2011 | 04:17 PM
ralphy_2002us
I will check and see
