fuel system ground failure
Old Feb 20, 2011 | 01:14 PM
dandan's Avatar
dandan
My 89 f150, 4.9, duel tank pickup is not getting ground to the fuel system. I have replaced all 3 pumps and grounded them direct to the frame. They run, but now the rear pump has failed. Is the way I grounded them OK? Please help.
Old Feb 20, 2011 | 05:28 PM
F150xlt's Avatar
F150xlt
Here's the schematic for a 88. The 89 fuel pump wiring should
be the same but the color code of the wires may be different.
All 3 pumps share the same ground which is G801.
G801 is a Black wire bolted to the radiator core support
behind the driver side headlight.
Manual describes location as LH inner fender behind headlight.
That ground wire is also used by a bunch of other items.
Both fuel gauge senders use the same ground G801.
Do both fuel gauge senders work?
The driver side headlight also uses G108 for ground.
Does the driver side headlight work?
Below is also a schematic for G801. It should be very close to the
89's wiring.
Old Feb 20, 2011 | 05:58 PM
dandan's Avatar
dandan
Thank you f150xlt I'm up and running.
FordAnne
Aug 15, 2023 08:21 AM
dive2663225
May 16, 2017 07:26 AM
Lee bias
Dec 29, 2016 10:40 PM
SiscoKid
Jul 9, 2012 08:54 PM
brookslion1
27
Jul 4, 2011 06:30 AM
