Hood Liner question
Old Feb 20, 2011 | 11:39 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
Hood Liner question
Any ex owner have the hood liner on their diesel? Pro's/Con's in mn im
thinking it would help keep the heat/noise under the hood. Not sure but, it might retain heat on the humid 90+ degree days here?
Old Feb 20, 2011 | 12:03 PM
Misky6.0's Avatar
Misky6.0
No liner on my '05 Ex w/PSD.
Not to highjack, but anybody have an under hood light?
Old Feb 20, 2011 | 12:10 PM
Snowseeker's Avatar
Snowseeker
I have a liner and light. At my buddies house we had my hood up and his 02 F350 hood up looking stuff over and noticed the light will go out after about 5 minutes.
Old Feb 20, 2011 | 01:01 PM
william_04_x's Avatar
william_04_x
My 04 has a hood blanket, but no light. No problems while towing in 120* temps here in the desert.
Old Feb 20, 2011 | 02:15 PM
airjeff's Avatar
airjeff
Has anyone added the stock underhood light? Know what the part numbers would be for the lamp holder and wire harness?
Old Feb 20, 2011 | 02:40 PM
Forest's Avatar
Forest
Had liner on my 03. Was not on the 05, so I bought it along with plastic push in supports. 15 minute job to install. I also added the rubber lip seal above radiator support frame. Both seemed to reduce noise level in the interior.
Hood liners do not cause the engine compartment to be any hotter. The airflow is what cools the engine compartment and the hood liner does not affect that. The liner will keep the paint on the hood cooler.
I elected to not install the factory light. From my 03, I don't remember that it put out very much light and thus not worth it.
Old Feb 20, 2011 | 02:56 PM
airjeff's Avatar
airjeff
I've seen little retractable hood lights. One of those might be a little more usefully anyway. I was just thinking that if I'm on the side of a dark rual road even a crapy light might be useful.
Old Feb 20, 2011 | 02:58 PM
TonyPDX's Avatar
TonyPDX
Who has the best price on the hood liner and retainers?
Tony
Old Feb 20, 2011 | 06:41 PM
Snowseeker's Avatar
Snowseeker
Those retractable ones can be salvaged from the 96 style chevy trucks or the 86 style ford trucks. Or new if you know a place.
Old Feb 20, 2011 | 09:59 PM
lowrango's Avatar
lowrango
my 2000 has both.
Old Feb 21, 2011 | 08:54 AM
jdadamsjr's Avatar
jdadamsjr
Neither on my 05....
Why I carry a flashlight cuz the hood lite does not lite up the road side as I walk out to take a ...
as far as hood heat - that little engine does a poor job of heating my black hood more than the Texus sun in August!
Old Feb 21, 2011 | 09:49 AM
Matt M, PA's Avatar
Matt M, PA
I added both to my '05. Neither were factory installed in 2005.
I just went to the dealer and ordered both. It's long ago and I don;t have the part numbers, but asking the dealer to look up an 04 or 03 hood pad and underhood light should get the job done.
I wired my underhood light to work when the parking lights are on.
Old Feb 21, 2011 | 09:39 PM
dent wiz eric's Avatar
dent wiz eric
i dont understand fords rhyme or reason. I have 2 05 x's in the garage now the limited has a liner but no light the eddie bauer has neither. both trucks were bought new and both are 6.0 's. I dont notice any difference in noise or heat between trucks.
Old Feb 22, 2011 | 07:44 AM
Snowseeker's Avatar
Snowseeker
The liner is actually a fire blanket. In the event of a under hood fire the plastic clips that hold the liner to the hood melt and the liner falls down on the motor and with the heat of the fire wraps itself around the motor snuffing out the fire.
Sometimes is vehicles have neither the liner or light the hood has been changed from an accident.
Old Feb 22, 2011 | 08:07 AM
Matt M, PA's Avatar
Matt M, PA
The pad removal must have been a mid-year thing for the 2005s. I ordered mine new and it wasn't on the option list. At the same time, Ford stopped putting the mats in the console and cubby bin. (I bought them at the parts counter and put 'em in) It's all part of de-contenting to save money for the maker.
Hood pads are for heat and noise. They help protect your hood's paint, and help reduce noise getting into the cabin. I have read more than once about fire suppression but I jsut don't buy it. I just can't see this working in actuality. All clips would have to give at the same time, and the blanket cover the engine well enough so suffocate the fire.
