ex's power steering issue
Old Mar 4, 2011 | 09:57 PM
  #31
almercenter's Avatar
almercenter
I used to have an '02 F350 that the power steering whined really bad and it steered too stiff w/only about 25k miles on it. I flushed the system and put in synthetic. That solved it. Sold the truck w/137k miles on it and didn't have a single issue w/ noise or stiffness.
Old Mar 29, 2011 | 10:46 PM
  #32
CrzHelm's Avatar
CrzHelm
well last week I completely drained the power steering system and refilled it with new fluid and 1 bottle of lucas. I gave it a few days to work in and still no difference at all. The engine speed makes no difference either. I can put it in neutral, rev it up, no brakes, and it still dont turn. I know some of you are looking at the big tires and dual stabilzers as adding to the problem but 6 months ago the truck was all stock and the problem was the same. Did all new ball joints too. As soon as you start moving its fine. So question remains... Box or Pump?
Old Mar 30, 2011 | 08:21 AM
  #33
Snowseeker's Avatar
Snowseeker
Weak pressure relief valve in the pump.
Old Mar 30, 2011 | 06:03 PM
  #34
tfs2403's Avatar
tfs2403
Hi guys, I tried a bottle of the Lucas and topped off the fluid, drove it, turned it almost to lock both directions several times, still no difference.
I was thinking of drain and new synthetic fluid?????? should I spend the money or save the $$$ toward a new pump?
Thanks
Robb
Old Mar 30, 2011 | 06:40 PM
  #35
EXv10's Avatar
EXv10
I would put a new pump in it. They are only about $65 and easy to change. You will need one anyway and don't forget the new belt.
Old Apr 2, 2011 | 08:16 PM
  #36
CrzHelm's Avatar
CrzHelm
Is the pump that easy to change? i dread getting an oil bath removing it. any tips? I almost wish it was the box. I already adjusted out the play and Im just nervous about it.
Old Apr 3, 2011 | 06:03 PM
  #37
EXv10's Avatar
EXv10
Oil bath?.......come on, just fix it.
Old Apr 3, 2011 | 06:15 PM
  #38
Snowseeker's Avatar
Snowseeker
Yeah, put your hazmat suit on nancy and get out there!
Old Jul 21, 2011 | 02:06 PM
  #39
BernMidwest's Avatar
BernMidwest
I had a similar problem with power steering not really being there when not giving it gas...I found myself two footing to get in and out of certain places. THEN one day got in the truck and no power steering at all!!!! Changed out the pump...still nothing!!!!
I have no idea where to go with this. Gear box, brake booster, perhaps collapsed or clogged line. However it seems as though fluid is getting through the lines and I have some brakes...there is a little kick back or fluttering when really stopping hard.
any ideas is appreciated!!!!!
thinksnow
May 6, 2015 06:20 PM
Fastback460
13
Apr 29, 2013 12:32 PM
jbilliel
Jan 12, 2008 05:38 PM
Hooker Bob
Feb 26, 2006 07:05 PM
