300 issues
Old Feb 20, 2011 | 10:57 AM
big-ugly's Avatar
big-ugly
300 issues
This morning I drove down to the gas station to put some air in a tire, and I noticed that when I started driving the truck was bucking and running like crap. It was noticable starting in 1st, and really noticable when I would shift to second. After that it seemed like it was running perfect. It was acting like I was starting in 3rd and shifting to 4th. Any idea whats going on here? I have read a lot about the EGR issues.
Old Feb 20, 2011 | 03:36 PM
Harte3's Avatar
Harte3
Yup, sounds like worn out EGR plus the catalytic converter might be plugged.
Old Feb 20, 2011 | 04:01 PM
big-ugly's Avatar
big-ugly
Thanks for the reply. Maybe next weekend I will have some time to tear into it a little.. just recently found a blown pan gasket as well.. Might just yank the motor and freshen it up some, new clutch, etc.. Good time to chop the cat out.
Old Feb 20, 2011 | 08:16 PM
rikard's Avatar
rikard
A vacuum gauge can tell if your cat is plugged and you might as well pull the codes and see what the computer says. When my MAP sensor failed it didn't set a code for the MAP sensor but it did set a lean code. When I disconnected and plugged the vacuum hose it ran better. I checked for the 5v reference voltage on the MAP connector and checked the temp sensors and TPS. Still not sure I replaced the MAP with a JY one which solved the problem until I picked one up from Napa.
regards
rikard
Old Feb 20, 2011 | 08:23 PM
big-ugly's Avatar
big-ugly
Well after work I drove the truck another ~30 miles, and this problem just disappeared. Not really sure whats going on. Tomorrow after school I'm gonna pull the plugs and see if they have any carbon build-up. I am thinking a 6liter tune-up is in order.
Old Feb 20, 2011 | 08:40 PM
rikard's Avatar
rikard
Never a bad idea to change the tune up items if in doubt about their age or condition. While I was checking the MAP sensor issue I replaced the wires, cap, rotor, and cleaned the 1 year old Autolites. The coil to distributer wire and #5 wire had discolored terminals and along with the cap and rotor were at least 5 years old but they were still working.
regards
rikard
PS Good to see the 21 Motorcraft Car win the 500
Old Feb 20, 2011 | 08:42 PM
big-ugly's Avatar
big-ugly
X2 on the Ford winning the 500!
Like I said earlier, the motor may be coming out of my truck in the near future, would be a great time for a tune up.
Old Feb 20, 2011 | 09:53 PM
6CylBill's Avatar
6CylBill
Good luck Brandon. Keep us updated
Old Feb 21, 2011 | 04:42 PM
big-ugly's Avatar
big-ugly
Pulled the plugs today after school, and they were completely coated. I cleaned them up with the sand-blaster and the truck is running a lot smoother now. Definately time for a tuneup.. Now I gotta talk my dad into helping me yank it out, replace the clutch, gaskets, a tuneup, and whatever else I can find while I'm there, AND get it back in the truck in a weekend... Oh Joy!...
Old Feb 21, 2011 | 06:35 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Take it to Autozone or Napa and pull the codes while you're at it.
Old Feb 21, 2011 | 06:39 PM
big-ugly's Avatar
big-ugly
Thanks for the advice. Probably wouldn't be a bad idea before the engine comes out.
Old Feb 21, 2011 | 08:16 PM
StumpPullerF1's Avatar
StumpPullerF1
I've had a similar issue, i just replaced the cat and now im thinking egr. Is yours showing any codes?
Old Feb 22, 2011 | 07:23 AM
big-ugly's Avatar
big-ugly
I haven't checked mine for codes yet, but I am sure it will show something when I do. I am sick today, so it probably won't happen for a little while.
priorityautorepair
Escape & Escape Hybrid
Dec 26, 2014 08:14 AM
Edge74
Jan 19, 2014 07:33 PM
dieselsubmariner
15
Jun 23, 2013 03:35 PM
n20
18
Dec 29, 2010 11:33 AM
