Door open light on dash
Old Feb 19, 2011 | 05:08 PM
BLADE35's Avatar
BLADE35
the door adjar light is always on and the dome light wont shut off untill it runs its coarse and computer or battery saver relay shuts it off. I looked for a door pin or something but didnt see anything. Is there a switch or something inside the door panel. maybe a wire shorted out? Thanks for your help
Old Feb 20, 2011 | 09:22 AM
cheezit's Avatar
cheezit
failed door ajar swich. you need a scan tool that can read pid data to find out what door the issue is in.
Old Feb 20, 2011 | 09:51 AM
katiesdad7's Avatar
katiesdad7
99% chance it is the back hatch. Just slam it and all should be good again. This is a normal problem on the Ex.
Old Feb 20, 2011 | 03:56 PM
Jigger2020's Avatar
Jigger2020
his profile says F350, I think Cheeze it is right, AGAIN
Old Feb 20, 2011 | 03:59 PM
cheezit's Avatar
cheezit
I cant help it.... Ive been at this for near 20 years ...
based on that you think I would be even better..
o ya Im humble too
Old Feb 20, 2011 | 04:52 PM
Jigger2020's Avatar
Jigger2020
Well done Cheezit, we're lucky to have you, really
Old Feb 20, 2011 | 04:53 PM
dchamberlain's Avatar
dchamberlain
I've read here a number of times that the door switches, which are in the door latches, can get sticky. Hose them down good with WD-40 and work it in good by opening and closing the door. I know a lot of people keep them going this way.
Old Feb 26, 2011 | 11:38 PM
BLADE35's Avatar
BLADE35
so if its a failed door adjar switch is it in the door and would the same part fit all doors. now I could try and change the driver side switch and see what happens.
This is what I did waited untill all dome lights went out manually open doors without keypad {keypad triggered dome lights} open driver door NO dome light came on. open other doors dome light comes on. So im thinking i need a driverdoor switch. Is the switch hooked to the little arm that goes into the door. I had the door panel off before but didnt pay attention to the guts of the door thanks for your help guys
Old Feb 26, 2011 | 11:39 PM
Skip1970's Avatar
Skip1970
will a scantool tell you on the older 2000's what door it is?
Old Feb 27, 2011 | 10:46 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
...........Yes!
Old Feb 27, 2011 | 11:03 AM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
Good advice...I had this problem with my '01 Excursion...hosed them down with WD-40 or LPS and switches would free up!
Old Feb 27, 2011 | 11:11 AM
sweeted's Avatar
sweeted
Yep,this has worked for me on a 2002 and a 2004 F-350.WD-40 or a good bath of silicon.
Old Feb 27, 2011 | 01:03 PM
BLADE35's Avatar
BLADE35
Ok I am going to try the wd-40 or something and give the latch a good spray.
Old Feb 27, 2011 | 02:15 PM
BLADE35's Avatar
BLADE35
the wd-40 worked great.It turned right off after I oiled the driver door. To trouble shoot. the computer shut off that circute to the bad door.(Forced shutdown) By not turning on the dome light when i opened the door after the forced shutdown I knew it turned that circute off.So it singled itself out. So I guess you can kinda trouble shoot this without a scan gauge.
Old Feb 27, 2011 | 03:41 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Actually, if one does it, it's time to WD40 all the doors!
