Sponsored by: Real Truck
Electrical Problem
Old Feb 19, 2011 | 05:03 PM
dpleva's Avatar
dpleva
Cool Electrical Problem
I have a F250 V10. Today I jumped another vehicle. Turned off my truck and it would not start again. Some of the relayes will buzz . Battery has a full charge. Horn relay will buzz but the horn won't honk. Windshield wipers will go on slowly as you turn the key but the switch is off. I took off the negative side of the Battery figuring it would reset itself but no dice. Any ideas?
Old Feb 19, 2011 | 05:30 PM
artfuldodger's Avatar
artfuldodger
Sounds like a bad battery terminal connection made worse by putting the cables on. Clean both terminals and both cable connectors, preferably with the right tool made just for that job.
Old Feb 19, 2011 | 06:20 PM
TexasRebel's Avatar
TexasRebel
relays buzz?!
they should click
