is this the right tranny fluid
on
It's all about the clutch and band material being compatible with the additives in the oil. I could be wrong but I doubt if a tranny could be "ruined" in the short term but might suffer a slightly shorter long term life with incorrect oil. Other than the friction material there is nothing in there that would be adversly affected by a different type of oil. I would be willing to bet you could run any tranny fluid in any tranny and never notice a difference. Don't forget the oil people want to sell their oil and don't want their profits diluted by other brands and types. When it comes to making money and destroying the competition people will put just about anything on a label they can get away with. I was reading some info on a protein/power bar today and they went on and on about how healthy and pure thier bar was but when I read the (required) ingredients it had 25% cholesterol and was about half sugar.
The oil companies didn't come up with the different specs for oil. The auto companies did that because there are different requirements. I know that running the wrong ATF will be noticed by the owner since in many cases he will be buying a new transmission. It's that critical.
Different fluids have different frictional characteristics. If you run the wrong fluid friction materials either become very grabby, resulting in harsh shifts, or they slip, which quickly results in a dead transmission. Some fluids are too thin for older transmissions. Try running MERCON SP in a 4R100. See if you can drive it 500 miles before it welds itself together due to lack of lubrication. I'll bet you can't do it.
on
Coastal Synthetic blend?
I am in the process of changing out my tranny fluid/filter on my 2001 F250 and in my Chilton's Manual it says not to use Mercon V. I didn't see this before I bought the fluid and my local Auto Zone had Coastal Multi-Vehicle Synthetic Blend Mercon V so I bought it. Can I use this fluid?
Also it says to drain the torque converter when draining the pan but the converter does not appear to be accessable like it says it is in the manual. Is there access to the torque converter drain plug on my truck or should I just stick with dropping the pan and replacing the filter?
Sorry for my ignorance but this is my first Ford vehicle so I'm learning as I go.
on
There is access. There should be a rubber plug on the bottom of the bellhousing.
Things changed but the manual did not. It is now out of date with the CURRENT recommendations.
The manual I bought is the Chilton manual for Super Duty Trucks/Excursions from '99-'10 models. I just bought it the other day so its brand new but that doesn't mean that the info inside is completely up to date.
It says not to use Mercon V unless the Owners Manual says otherwise, but I don't have the owners manual so I didn't know if Mercon V was applicable to my year model. I put the Coastal Mercon V in it and everything seems fine so far.
#28
#29
