NO fun , too WINDY
Old Feb 19, 2011 | 12:06 PM
bren7176's Avatar
bren7176
NO fun , too WINDY
So Ive got to replace the upper and lower ball joint on both sides , While im at it im replacing the end link and shocks . After that's done this week Im got to replace some O-rings on the engine to stop some oil leakage . Now only if it would warm up to do this. Went out today to look at doing this but its too windy out . and cold ....
Brendan
Old Feb 19, 2011 | 12:45 PM
SpringerPop's Avatar
SpringerPop
Good idea!
If you work on your truck when it seems fun, it WILL be fun.
If you're freezing, it will be drudge.
Attitude is everything!
Keep it positive!
Pop
Old Feb 24, 2011 | 03:01 AM
bren7176's Avatar
bren7176
Okay so i got the new end links in the new shocks on and the upper and lower ***** joints done and when i was at it the front brakes with new calipers . So i still have a clunking in the front end drivers side . Im now thinking the bushings in the leaf spring may be the cause of this . From the area its coming from I say its the rear drivers side bushing or shackle . I think its the bushing in the top of the shackle . Is there a replacement for this for this or does it come with the shackle?/
thanks
Brendan
Old Feb 24, 2011 | 04:55 AM
WA.Ranger's Avatar
WA.Ranger
Energy Suspension makes a kit.
Old Feb 24, 2011 | 08:39 AM
DieselCamper01's Avatar
DieselCamper01
It is "probably" sway bar bushings but wouldn't hurt to check all the bushings up front
Old Feb 24, 2011 | 01:10 PM
bren7176's Avatar
bren7176
the clunk is coming form the drivers side frame rail area , so that why i think its the bushings there ..
Old Feb 24, 2011 | 09:55 PM
DieselCamper01
If you feel a clunk through the floor board it is almost always the swaybar bushing but I am not sure what the symptoms are of a bad spring bushing. Post back if you figure this out or if you need more help
Old Feb 25, 2011 | 07:34 PM
bren7176's Avatar
bren7176
well the sway bar ends links new so maybe the bushing that hold the sway bar are shot will look tomorrow, Just got home had to get the stupid parts place to replace on of the batteries it only had half the CCA amps. the jerks there said charge it .I was look i just drove 50 miles its not charging replace it .. So now both bats are good to go and I found the plug on the block heater was shot so replaced that . Dam cold lets you find all thats broke....
Brendan
Old Feb 25, 2011 | 07:50 PM
don77's Avatar
don77
could be leaf spring hiting frame mine does that
Old Feb 25, 2011 | 08:46 PM
bren7176's Avatar
bren7176
you know I never thought about that. Thanks I will have to look..
Brendan
Old Mar 22, 2011 | 11:13 AM
bren7176's Avatar
bren7176
Okay I finally got around to changing the sway bar bushings . That was the problem no more clunking whooo hooooo Next job is install the leveling kit . ...
Old Mar 25, 2011 | 02:17 AM
bren7176's Avatar
bren7176
So finally took it for along drives alot nicer ride with all the new parts on the front suspension. Now cant wait till later today I get my baby back from the body shop had to have a oops to fixed . Dam snow storms i clipped a wooden post in a white out . Hit the ds rear door and cab corner and box. Dropped the truck off Wednesday it will be done Friday.. wooo hoooooo.....
Old Mar 25, 2011 | 07:28 AM
riverrat41's Avatar
riverrat41
Thanks for your service if that is you in your avatar.
Old Mar 25, 2011 | 11:44 AM
bren7176's Avatar
bren7176
Yes that me in my avatar . That was taken in FOB Grizzly , Iraq 2009. The truck in back is the FOB fire truck I was the head Chief of the fire dept ..
Thanks
Brendan
Old Mar 26, 2011 | 03:12 AM
bren7176's Avatar
bren7176
got my baby back from the body shop , the guy did a great job for the money . think this summer im going to have him the whole truck repainted ..He even used the door and fixed it you can never tell it was crumpled in. this shop did a fantastic job and saved me money by fixing instead of replacing . Hard to find a shop that fixes theses days ..
Flat_Ford
Nov 5, 2010 04:17 PM
Bart R
Feb 12, 2008 10:17 AM
olfordsnstone
17
Nov 24, 2006 06:21 PM
cigarxtc
Oklahoma Chapter
Apr 16, 2005 09:23 PM
Peach
Iowa Chapter
Oct 30, 2004 09:59 AM
