Brake line failure
Old Feb 19, 2011 | 09:57 AM
Jugger's Avatar
Jugger
Brake line failure
Heres a heads up to check your rear brake hardline next to the muffler. My trucks a 97 expedtion. The hardline developed a hole in it and the pedal went to the floor. The truck had zero brakes. It wouldn't even hold the truck at idle in gear. Fortunately the truck was parked and i was just getting it into gear. The hole appears to have been a result of rust on the line. The leak was located about 8 in from item 2a442. Thats on the right side of the image below.
Heres a link to the replacement part. Item 2267
http://www.fordparts.com/Commerce/Ca...WLK+LH7viyyDAr
Old Feb 19, 2011 | 11:32 AM
richardliebert's Avatar
richardliebert
I just experienced a similar issue with my 98 Exp. however I retained braking power to 2 wheels and was able to drive the car to my dealer. My guess is the master cylinder was redesigned for 98.
Old Feb 19, 2011 | 04:49 PM
projectSHO89's Avatar
projectSHO89
If you suffer a catastrophic brake line failure, please file a formal complaint at NHTSA.gov
I've seen enough of these (and had one of my own) that I suspect a recall could be forced if enough formal reports are made.
Old Feb 19, 2011 | 08:06 PM
orleec's Avatar
orleec
Mine leaked right at the bottom of the driver area. It was dripping, but I noticed the leak soon enough so as not to lose brakes. When I inspected it, the whole thing was rusting going to both wheels, and from the pump area. I found suitable replacement as I listed here:
https://www.ford-trucks.com/forums/1...ake-lines.html
HELMUT RONER
WTB - Parts & other
Apr 27, 2016 12:48 PM
pitpawten
Apr 7, 2016 09:01 AM
meangreen92
Oct 15, 2014 04:30 PM
singleshot1
Apr 29, 2014 01:59 PM
datdawg
17
Jan 11, 2011 07:33 AM
