Where is DPFE?
Old Feb 19, 2011 | 09:45 AM
jaykaran's Avatar
jaykaran
Where is DPFE?
Where is DPFE located in a '96 F150 5.0L? I can't find it in the Haynes Manual. Does it have an alternative name?
Thanks
Old Feb 19, 2011 | 10:34 AM
Conanski's Avatar
Conanski
The DPFE sensor is attached to the EGR tube via a pair of smaller tubes so you should be able to locate it by tracing those.
Old Feb 19, 2011 | 10:49 AM
subford's Avatar
subford
Top RH front of engine (location D1 in diagram):
Old Feb 19, 2011 | 05:34 PM
rla2005's Avatar
rla2005
This photo from my buddy Al might help: 1996 Ford Bronco Technical Info picture | SuperMotors.net
The silicone tubes running to the DPFE are known to deteriorate over time. The small leakage will affect the way the DPFE measures the difference in pressure. The EGR tube is also known to crack and leak or clog up with deposits.Both of which can also trigger EGR related codes.
Old Feb 19, 2011 | 09:06 PM
jaykaran's Avatar
jaykaran
Found it. Thank you all so much. Also I found another thread that explained how to test it and I tested and I am not getting any change in voltage with vacuum. It is stuck at 0.28 volts. So I am going to replace it and see if the P0401 code goes away.
Old Feb 20, 2011 | 08:56 AM
rla2005's Avatar
rla2005
Could you post a link to that thread?
Old Mar 11, 2011 | 11:47 PM
artfd's Avatar
artfd
Don't know what thread the earlier poster was referring to, but here is a thread on testing the EGR/DPFE system; Part 2 -How to Test the Ford EGR Valve and DPFE Sensor
Old Mar 12, 2011 | 02:50 PM
rla2005's Avatar
rla2005
Thanks for the link!
Shakina Glory
4 Cylinder Engines
Oct 28, 2019 03:18 PM
forder
Sep 21, 2016 10:00 PM
blieux1
1997 - 2003 F150
Feb 24, 2007 11:14 AM
fffrdowner
3.0L V6
Nov 4, 2005 07:36 AM
fam
1983 - 2012 Ranger & B-Series
Mar 24, 2003 12:29 AM
