94 axle noises
Old Jun 28, 2011 | 09:17 PM
coreylasalle's Avatar
coreylasalle
mine there was no sign of a bearing and it wore the outer shaft so i had to replace that too. the bearing kit costs <20 bucks if that is indeed the problem. the axle shafts kinda flop around if the bearing is bad
Old Jun 28, 2011 | 09:49 PM
f350rebel7788's Avatar
f350rebel7788
Disabled USMC Veteran
Well when I pulled the shaft out to do the u joint, the teeth on the shaft looked fine... I guess if that is the problem, I caught it early enough?
Old Jun 29, 2011 | 06:13 AM
DIYMechanic's Avatar
DIYMechanic
That really sounds to me like something in the drive shaft or the pinion side of the differential. It is too fast to be on the ring side of the diff or in the wheel, axle or hub. I would say that the best thing to do at this point is going to be to drop the front drive shaft and check the double cardon joint and the pinion yoke for play.
Old Jun 29, 2011 | 09:57 AM
dclack's Avatar
dclack
Originally Posted by f350rebel7788
i let this post sit for a little while, and still haven't got the problem figured out... all the u-joints are good... the sound (metalic clinking every time the wheel goes around, and the clink speeds up as i accelerate) comes right from where the diff is, and only does it when in 4x4. one thing that i noticed that may be a factor (don't really know a whole lot about this topic) is that when i "lock" the hubs (warn), they click out of unlock, but no click when "locked". Would this be of concern???
Your description here really sounds like a bad ring gear. If you haven't already, you've got to get the cover off the diff housing. It's a really simple job.
the_auto_tech
Dec 3, 2013 04:13 AM
03F350XLT
Jul 31, 2011 09:15 PM
chrismartinez0
May 27, 2010 08:12 PM
BigJake34452
Mar 30, 2010 08:26 AM
