Sponsored by: Real Truck
Trailer braking system
Old Feb 18, 2011 | 07:01 PM
harley3348's Avatar
harley3348
I have a 2002 F250 7.3 PSD 4x4 crewcab shortbed. A friend has asked if I could tow a 5000 lb trailer for him. I have the tow package which has the large plug under the rear bumper. My question is if I plug in the trailer and step on the brakes will that activate the trailer brakes.
Harley
Old Feb 18, 2011 | 07:03 PM
RZAR's Avatar
RZAR
Only if you have a trailer brake controller installed on you truck.
Old Feb 18, 2011 | 07:10 PM
m350's Avatar
m350
LOL,,,,a Barking system,,,Woof-Woof,,,aarf-aarf,,Haa !,,Just messin with ya !!
If you dont have a Brake controller,,,the Brakes will not be applied on the trailer !
The Tow Command system started with the 05' and up SuperDuty trucks,,,these trucks,,if they Had Tow Command,,,came with a Factory Ford Built in Brake Controller,,,a sweet setup !!
Old Feb 18, 2011 | 07:20 PM
fz1dave's Avatar
fz1dave
Super Duty
Funny mix-up on the title. I thought this was gonna be about a dog barking before you backed into something.
As the others have said, you need a controller for the trailer brakes to work.
Old Feb 18, 2011 | 07:22 PM
MexicanScaper987's Avatar
MexicanScaper987
Even without brakes, depending on your terrain and where your going, towing 5,000 lbs with out trailer brakes isn't to big of a deal. Most single axle trailers are between 2900-3500 lbs. Some medium sized tree chippers that don't have brakes weight in close to 5,000 pounds as well.
Old Feb 18, 2011 | 07:48 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
In Texas, double axle utility trailers tagged at 7k don't have to have brakes installed. I've pulled several 3-5k trailers, mostly on I70 in Colorado with a Ranger or an Expedition and never once used a brake controller with any of them. 5k trailer on 5k truck with 6% grade was dicey sometimes, just gotta drive smart.
Don't be an idiot and it won't be an issue. But no matter what, if you lock up the brakes going 70mph, not even a controller will save you from rolling the trailer, and probably your truck.
Old Feb 18, 2011 | 08:04 PM
TennesseeMustangPerf's Avatar
Lol, yeah I did not know what to expect on this one. Thought it might be some sort of trailer alarm system or something.
O.P.- The best way to tell is to hook the trailer up and see if you have lights. Your truck being a 2002 though, it will not be integrated into the dash, but rather will be a command module under the dash, usually has a green/amber LED and a slide switch.
Old Feb 20, 2011 | 12:04 PM
harley3348's Avatar
harley3348
Trailer braking question
Thanks to all for the help on this one, especially the humor about the barking. Sorry for the typo. I will try harder next time. Thanks again.
Harley
saltbranch
All Things Towing
13
Nov 26, 2013 04:36 PM
lloydmiiller
1997 - 2003 F150
Sep 19, 2011 04:20 PM
scuba1954
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
26
Jan 18, 2008 11:08 PM
Agapemou
Dec 26, 2005 07:34 PM
Bronco532
Jul 7, 2004 10:11 PM
