Bio diesel
Old Feb 18, 2011 | 06:40 PM
RRranch's Avatar
RRranch
Bio diesel
You guys in Dallas, Ft Worth, Houston and all over the midwest need to try this stuff. I know you all have bio stations all over your area. We only have one and it's new.
I worked on these trucks at the dealer when they first came out and I swear my truck is running just like the day if drove off the lot. It does smell like a burger joint slightly but who cares, not even halfway through my first tank of 50% commercialy made bio it's stronger, quieter, no smoke at all, no shaking, just perfect. If you haven't tried it yet then go do it. The government snuck this ULSD crap in on us slow so we wouldn't notice the difference. Well, now I remember what it was supposed to run like!
My next fill up will be just straight bio. I'm not even gonna tell you what I payed for this fillup. You'll all get mad at me. It's much cheaper than ULSD though at the place I found and these days every penny counts. The place here is making theirs from virgin veggy oil and a little bit of tallow. Nothing recycled. It's still much cheaper than dino and apparently much better! I'm on my third tank full now.
Old Feb 18, 2011 | 07:36 PM
bearhugger's Avatar
bearhugger
Wish i could find a bio station close to me,i live in spring tx,at least my money would stay in the USA.
JIM
Old Feb 18, 2011 | 07:37 PM
RRranch's Avatar
RRranch
I think I saw a place in Spring. You should search online for it. It might have been one of those Bio Willie truck stops.
Old Feb 18, 2011 | 08:09 PM
F350-6's Avatar
F350-6
Bio is great. Outstanding lubricity, different combustion characteristics that just make the engine sound smoother, and overall a generally good experience.
Just keep in mind that pure bio has fewer BTU's per gallon than old fashioned #2, so the closer you get to B100, the more your mpg's will suffer. You'll also lose a bit of power due to the lower energy content. We're not talking really big differences in the numbers, but a drop in mpg's should be expected if you go B99.
Old Feb 18, 2011 | 10:18 PM
Ken_C's Avatar
Ken_C
its so hard to come by biodiesel in southeastern michigan. I have to drive an hour to get to a pump that has B20. I talked to a guy from a local oil company today who wants $4.55 a gallon for B100 delivered in bulk not including all applicable sales and highway taxes. with a 150 gallon minimum order... I just dont think I can pay that and feel good about it. I dont have storage for bulk amounts at the moment. but I did locate an old 275 gallon heating oil tank today for $50. that was before I found out how much I would have to pay for biodiesel
Old Feb 18, 2011 | 10:32 PM
FARM69's Avatar
FARM69
I thought bio had higher btu's than regular dino? I don't think you can find straight bio up here but %20 is pretty common. It's more expensive than dino though... even when the plant is only 20 mile away.
Old Feb 19, 2011 | 06:22 AM
427 fordman's Avatar
427 fordman
I'd like to try some sometime but it's not readily available around here in small town SD. I live at least 25 miles from any city and don't recall seeing it anywhere for that matter.
RRranch's Avatar
RRranch
That's pretty screwed up. I know it's not even taxed in Texas. I didn't think there were any federal highway taxes on it anywhere either. You guys should check into that. The law down here says mixes at gas stations can only tax the portion that is ULDS and I called a couple places on it. The producers did lose the federal dollar per gallon subsidy on it but the only time it should be costing more than ulsd is if they are just crooks. The plant nearest me that went out of business was telling people 10 bucks a gallon back when diesel hit 5. That is just not cool.
Old Feb 19, 2011 | 07:09 AM
stubborn66's Avatar
stubborn66
There is a local guy who is making it here and with using waste veggie oil it is costing him just over $1.00 to make. He is telling me that you cannot use a regular old oil tank to store it, it will rust it out on the inside. You need plastic, aluminum, or stainless steel storage tanks.
He also said in PA if he gets registered and pays the highway taxes on each gallon he makes, in return he can receive tax credits. He said if his volume was bigger it would be a winner but it is not worth the paperwork yet.
Old Feb 19, 2011 | 08:19 AM
MTEPERA's Avatar
MTEPERA
I think my truck runs better on it as well, i buy when i can @ biowillys, i think it is B20 to B85. I seen info on here about how it acts as a solvent. it definently disolved the 13 years of gunk in my tank and fuel lines. Luckily it was time to change fuel filter after about 500 miles of first fill up of Bio. When i pulled the filter, i could not belive how much black gunk was on it. Never looked anything like this before. if using it for the first time, i would check or replace fuel filter after first 250 to 500 miles.
Old Feb 19, 2011 | 10:01 AM
Talyn's Avatar
Talyn
Ken, where are you at? I know of a few down there.
I believe you are thinking of Ethanol, the stuff for gassers, It runs hotter with a bit less efficiency.
Lots of people getting the govt after them cause they are not paying "road taxes"
But then, the road taxes are far to high for the quality of work they do to the roads.
At least here in michigan.
600 Gallons I think is where they usually get pissed off.
But yes, you are correct about the tank stuff.
Plastic is okay for storage, but not for making.
Can have a melt down, you are using LYE while making it.
Old Feb 19, 2011 | 10:24 AM
RRranch's Avatar
RRranch
It's not gonna rust out my farm tank is it? It's 100 gallon steel tank.
Old Feb 19, 2011 | 10:45 AM
Ken_C's Avatar
Ken_C
William, Im near metro airport. the closest place (that I know of) is in manchester. the place out on will carelton rd doesnt have bio the last few times i checked. the place in manchester has it winterized and blended b20. I run it when ever I can get out there to buy some. otherwise its ULSD with some power service added to it. I have seen lists on line here and there that show all kinds of places that have bio but when I call and check I find out that "oh that was years ago we dont have any of that anymore"
thats good to know about storing biodiesel. so if you have a steel fuel tanks on your truck youre just waiting to rot the tanks then i guess?
Old Feb 19, 2011 | 10:51 AM
Ken_C's Avatar
Ken_C
actually biodiesel has fewer btus than ulsd
Old Feb 19, 2011 | 11:15 AM
Talyn's Avatar
Talyn
If your using the tank, no worries, but if your letting it sit, then its bad.
Lots of people use steel drums to settle their bio though.
