Soft brake pedal, after bleeding lines
Old Feb 18, 2011 | 05:07 PM
chris64's Avatar
chris64
So close to taking it out of the barn.
All new brake lines, wheel cylinders, and calipers.
Master cyl looks good, but the pedal is still mushy, I can pump it a bit, then I can push it almost to the floor.
Time for a new booster?
Not too pricey, any tricks to replacing booster ?
Weekend off, and the weather is great, I want to go for a ride!
Thank you, C
Old Feb 18, 2011 | 05:17 PM
RRranch's Avatar
RRranch
sounds like booster. There is a service bulletin on these for just this problem. Don't just go to the parts store and get one, you need to make sure to use the proper part number for the zero loss booster. Or just ask for a 97 booster. I believe they came with it but I'm not 100% positive.
Oh when you bleed them do NOT pump the pedal. Just push down, open bleeder, close bleeder let up. That's it. And don't forget the bleeder on the abs actuator.
Old Feb 18, 2011 | 11:46 PM
oldbird1965's Avatar
oldbird1965
I gravity bleed mine, firmed it up. I have read about the zero lost booster but have never tried it.
Old Feb 19, 2011 | 12:01 AM
Ken_C's Avatar
Ken_C
sounds like air still in it
Old Feb 19, 2011 | 04:17 PM
chris64's Avatar
chris64
Replaced booster, pedal still soft after bleeding lines again. Getting a new cylinder tomorrow, so after that the entire brake system will be new. Getting closer...
Old Feb 19, 2011 | 04:35 PM
Action4478's Avatar
Action4478
How do you rule out the master cylinder by looking at it?...
Correct me if I am wrong , but doesn't the booster just assist braking?...
Old Feb 19, 2011 | 06:47 PM
RRranch's Avatar
RRranch
Boosters do cause that on these and it's real common prior to the 97 models. I've never seen the internals of one yet so don't know why but they do it.
Look at the size of your cylinder stamped on the side of it. Make sure the new one is the same size. They are misboxed a lot. The IDI and 94 had a smaller one then newer trucks. Also when you bleed it again do nearest to farthest bleeder and don't forget the abs actuator. No pumping. Just down and up. You aren't supposed to pump any abs systems.
Oh and check those parking brake levers. If they aren't back nearly to the edge of the backing plate when you pull the drum off then you need to fix them. That will cause your problem too. Then adjust the brakes to get a real slight drag on the drums. You should be able to turn the wheel easy but not spin it.
Old Feb 19, 2011 | 07:53 PM
Action4478's Avatar
Action4478
If the rear parking brake is stuck (on) the brakes will be firmer , not soft
If the braking system is hydraulic (& it is ) the assist cannot cause a soft pedal . Air introduced or oil fluid leaking past a seal will cause this ..I have been fixing brake issues for 40 years & have never had to replace a booster that wasn't leaking .When they fail ,the brakes are like manual used to be ...
You are saying that for some reason the vacuum boost on the early OBS systems is different than every vacuum assist on every other vehicle ?...I need to have this explained to me ,due to it makes no sense at all ...
Old Feb 19, 2011 | 08:40 PM
oldbird1965
Bleed nearest to farthest?
Old Feb 19, 2011 | 08:56 PM
Action4478's Avatar
Action4478
If you bleed front or rear (doesn't matter which you do first) till they are clear ).. you will be fine ...Again 40 years of bleeding brakes , it makes no difference what you do as long as the air is gone ... OP needs a MC ....
Old Feb 19, 2011 | 09:05 PM
WALJON's Avatar
WALJON
X2 and it needs to be bench bled before put on the truck.
Old Feb 20, 2011 | 01:34 AM
pjwoolw's Avatar
pjwoolw
Kinda funny. That was the only way I could get good pedal on the 86. Had to go shortest to longest.
Old Feb 20, 2011 | 05:14 AM
excavator's Avatar
excavator
When you have to bleed as many cars and trucks as I do and by myself most of time, this is what works great and fast. Just hook it up, pump it up to about 10 psi and then open up bleeder and close when straight fluid comes out. No starting engine and no pumping brakes. Some cars require just one tap on pedal while under pressure and that get the fluid past abs valve, but most of time it just works on it own.
Universal Bleeder Kit 0250 -- Motive Products Online Store
Of coarse on my big trucks, I want air in the brake lines
Old Feb 20, 2011 | 09:27 AM
oldbird1965
Why would you want air in the lines on the big trucks?
Old Feb 20, 2011 | 10:04 AM
WALJON's Avatar
WALJON
Air brakes silly LOL
