Soft brake pedal, after bleeding lines
Old Feb 20, 2011 | 03:21 PM
  #31
oldbird1965's Avatar
oldbird1965
I like the girls in your picture Rick. I bet they eat alot but I bet you don't feed them your beans because you have a lot of them! My Westie girl, in my picture, she doesn't eat alot. I'm one of the whiners, help me-help me equals very few beans to feed my dog, LOL!!
Old Feb 20, 2011 | 03:31 PM
  #32
Action4478's Avatar
Action4478
So you are jumping in on the bash me crap too ? At least you are honest & don't come across like a know it all...
Have you ever wondered why most of the heavy tech help in this forum has disappeared ?...
My avitar is appropriate, this place is going to the dogs ...
The only hope is , every problem can be solved with a new CPS or cleaning the FPR screen ...
Old Feb 20, 2011 | 03:51 PM
  #33
Action4478's Avatar
Action4478
BTW,,, since you obviously don't remember . I got my beans defending a member that was called a "hack " by a site sponsor .. Which I would have done for you too....
Old Feb 20, 2011 | 04:14 PM
  #34
WALJON's Avatar
WALJON
I don't hate you Rick LOL I still like your friends bike and just recently got rid of mine with the Banana seat hoping to get one like your friends real soon LMAO
Old Feb 20, 2011 | 04:21 PM
  #35
Action4478's Avatar
Action4478
cool ...
I'm only a threat to post w ****s ...
Old Feb 20, 2011 | 04:26 PM
  #36
MADVAN's Avatar
MADVAN
Originally Posted by RRranch
1997 and earlier diesel trucks equiped with vacuum power brakes--Low/creeping pedal:
Many owners have complained of a low or creeping brake pedal on their trucks, often mistaken for a bad master cylinder or Rear ABS valve. If the condition occurs after the vehicle has come to a stop, and no other brake concerns are found, (worn or out-of-adjusted brakes, cocked pads, or hydraulic problems) the condition is normal and the result of the vacuum pump replenishing the vacuum inside the power booster. Ford has developed a Zero-Loss Travel brake booster to correct this condition if the customer finds it unacceptable. This part is only for use on diesel-equiped trucks--P/N F5TZ-2005-CA--and is not a service replacement; it must be ordered by the part number, not vehicle application.
This condition is similar to the low brake pedal concern on all 1995 F-series that required a larger-diameter master cylinder:
Still make no sense at all? I guess I was just talking out my tail pipe huh?
High % of this comes from the driver,weak vac pump combo.
If you keep pressing and releasing the pedal in a short period of time at idle
some trucks can deplete the vac faster than the pump can make it.
Pedal still will go hard. The driver will feel the normal pressure
as if the pedal is falling and its not. Its do to it being harder than the norm.
B
Old Feb 20, 2011 | 04:31 PM
  #37
MADVAN's Avatar
MADVAN
Holy chit just got to the next page of tread.
OT and out
B
Old Feb 20, 2011 | 04:34 PM
  #38
RRranch's Avatar
RRranch
Very true. That's how my 94's original booster was. If I pressed and released it more than once it would be on the floor but it would hold. It was scary in traffic. I put a 97 booster on to fix that. It stays right where I adjusted it now. If you have a weak vac pump and or any other problems it can get pretty serious.
That other problem with the brake cams was also present on mine when I got it. Luckily I had a good teacher at my First Ford job. I've seen that on so many pickups when a customer came in saying their master cylinder was bad. I made it a routine to always clean, lube and adjust the rear brakes before going to far with it. That only paid .2 hours so they rarely said no. That should be the first part of any brake diagnosis on this type of system unless it's got an obvious leak or something.
Old Feb 20, 2011 | 04:41 PM
  #39
oldbird1965
Rick, PM sent!
Old Feb 20, 2011 | 04:56 PM
  #40
oldbird1965
To all others, I wasn't bashing Rick, not in any terms. He helps alot, equals lots of beans. I, on the other hand, aways need help, therefore no beans. That's what I was saying, period. Rick is a asset to this forum, sorry I'm not good at expressing it.
Old Feb 20, 2011 | 06:01 PM
  #41
bobssatellite's Avatar
bobssatellite
CK calipers 97 will mount on ether side If put on wrong side bleeder will be on bottom ,Needs to be on top of calipers to get all air out. Been there done that.
Old Feb 20, 2011 | 06:07 PM
  #42
WALJON's Avatar
WALJON
I like potatoes
Old Feb 20, 2011 | 08:57 PM
  #43
MADVAN's Avatar
MADVAN
I will pm you some beans glenn!!
I will send rick some gas!!! Its the side effect from beans
You go rick! I stand with ya!
IF anyone wants to send me some beans its ok with me
Rick helps many here for free and some cry here for free
Iam also just a dumb sob from a keyboard.
I might as well keep it OT
B
Old Feb 20, 2011 | 09:03 PM
  #44
MADVAN's Avatar
MADVAN
I like potatoes
Me 2----French!
B
Old Feb 20, 2011 | 09:37 PM
  #45
Iallwork's Avatar
Iallwork
Gave ya a rep point Glenn. Hope it helps your beans.
To other people thanks for all your help. Eating popcorn.
