how much rust is too much?
Old Feb 17, 2011 | 11:48 PM
jotram's Avatar
jotram
I know if you can put a screw driver thru a body panel it needs work, but how about those deep pits , how much rust is too much? when should you replace or repair it? Will just a wire wheel and some good primer be enough?
Old Feb 18, 2011 | 12:10 AM
jotram's Avatar
jotram
NOBODY GOTS NOTHING?
Old Feb 18, 2011 | 12:12 AM
jotram's Avatar
jotram
I was just wondering cause I have a 55 f-100 and most of its decent exept for those known areas, theres some deep pitting but it still seems strong.
Old Feb 18, 2011 | 01:27 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Any more than 6 lbs. of rust is too much.You should be fine.
Old Feb 18, 2011 | 03:27 AM
kenjh's Avatar
kenjh
to much rust ...well I tried to put an outside mirror in my truck and the bondo broke off wish there was some rust behind it..tried to grind off a bubble of rust on the door had to cover the hole with duck tape cuse now the rain runs through..every time someone slam's the passenger door I get a hand full on the running board..so the truck is getting lighter every bump!!...so to answer your question ..you never have to much it keep's twit's from leaning on your truck ,,you don't worry about your paint ..if you still have any..as long as the heater can make it warmer inside then it is out side ..your good to go ..
Old Feb 18, 2011 | 07:24 AM
WALFORD'S 56's Avatar
WALFORD'S 56
It will all depend on your skills or how deep your pockets are.
Generally, in the rust belt.....we look for better panels and install them. Don't forget, that in 60s and 70s and even 80s bondo was king, and these were just cheap work trucks. I bought replacement fenders from Mcphee Ford in Ohio and that was 1974....and I almost fell over when we got the price.....If the bondo and rust pits bother you...see a body shop and ask them some questions and pits to me are no big deal, but on a show truck they would be...
Old Feb 18, 2011 | 07:55 AM
cruisetopdown's Avatar
cruisetopdown
Generally rust is like cancer, it never truly goes away. To answer the question you must first decide the level of build that you are planning, then approach the rust accordingly. If you plan on a show truck you will want to remove all the rust, but if you want a nice daily driver then you can treat it with a converter which will last for several years..... If you can poke through the metal, it's gone and would need to be replaced. Heavy pitted metal that cannot be poked through can be treated, but you will need to temper your expectations on the longevity of the repair. Safety should be the number one concern, from carbon monoxide to generally keeping your feet warm and dry should top the list.
This of course is mho....good luck!!
w
Old Feb 18, 2011 | 09:32 AM
ALBUQ F-1's Avatar
ALBUQ F-1
No, any more than 7.84 lbs is too much. This has been established many times on the forum through rigorous examination.
Old Feb 18, 2011 | 09:52 AM
ibuzzard's Avatar
ibuzzard
Sorry,I thought it was understood that the Ford Rust Specification was to be regionally adjusted, i.e., Northeast, Rustbelt, etc..I stand corroded, I mean, corrected.
Old Feb 18, 2011 | 10:07 AM
kenjh's Avatar
kenjh
how can you get that much to stay on??
Old Feb 18, 2011 | 11:15 AM
ibuzzard's Avatar
ibuzzard
I live under the Redwoods, in a temperate rain forest.I use Fomoco Rust Adhesion Formula.NumberDummy helped me locate a case NOS.
Old Feb 18, 2011 | 06:45 PM
kenjh's Avatar
kenjh
I was sitting in my 54 ford thinking of this thread ,,and made the mistake of sticking a screwdriver in a rust bubble on the door post dammed if water started running out !!!.. so do I punch a few holes looking for water ,,or wait for it to find it's own way out?? an' your worried about rust....
Old Feb 18, 2011 | 07:18 PM
iwanaflattie's Avatar
iwanaflattie
if its surface rust or just pitted a nice wire wheel and some good primer will do, i think.if its structural rust(if its going to make your front end fly on the freeway,i would be worried.)
Kevin had a thread of how to deal with the worst rust https://www.ford-trucks.com/forums/8...n-build-4.html
even if your truck is rusty,some A holes will still sit on your fenders trust me
Old Feb 18, 2011 | 07:23 PM
ibuzzard's Avatar
ibuzzard
...so do I punch a few holes looking for water ,,or wait for it to find it's own way out?? an' your worried about rust....
Enlarge the hole just a bit,and add a container of Bars Leaks.
Old Feb 18, 2011 | 08:01 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On my door posts, they had a metal plate inside, near the bottom of the post, with the corners cut off and a hole in the center, to let water drain. But they get plugged with dirt. You can reach up with a wire from under the truck to clean it out.
