how much rust is too much?
thanks for the replies guys . I think I will try and save all the rust then weigh it ...My idea is that I want a truck that shines and is done right . My skills are pretty limited though. Im not really a sheet metal guy. So far I did the easy stuff like the frewall cleanup ,few spots here and there, yesterday I opened the front right cowl area .....$#@% Lots of work to do...more than I thought , and this was supposed to be the easy side . I Will post some pictures later and you can all critic my work,maybe give me some pointers!
THATS TOO FUNNY . I opened my cab corner and all that fell out was an old 5/8 wrench, dirt, 308 bullet , and 55 cents..and of course rust through..
Anyone have ideas on how to maybe reconstruct these areas so it does'nt happen again you know better ways than manufacturer?
Jotram,probably the easiest thing to do is keep the area clear of dirt/debris.My 59 has huge,accessible pockets,which I vacuum out when I clean the cab.I actually use them for storage of a tool roll,oil, etc..They are the perfect spot for moisture to collect,as ALBUQ F-1 stated.I thought of even drilling a small hole to drain any moisture,but haven't done so.
Steve
Steve
I was sitting in my 54 ford thinking of this thread ,,and made the mistake of sticking a screwdriver in a rust bubble on the door post dammed if water started running out !!!.. so do I punch a few holes looking for water ,,or wait for it to find it's own way out?? an' your worried about rust....
I agree with Steve. It's not so much that the trucks weren't designed right, but they've suffered from 60 years of deferred maintenance and neglect. Once they're cleaned and repaired properly, they'll last the rest of our lifetime and then some, with proper care.
to much rust?
Id say if its a show truck....... if its pitted only its fine. Just media blast it or sand blast it then maybe then body work. As long as the metal isn't to thin and a whole appears after blasting it will be fine.
.....now with that being said.....after blasting if pin wholes appear do not just pack it with filler. You will need to put new metal in. A wire wheel is good to get the worst of the canser out but thats not enough. It needs to be blasted to last.
I tell you from experiance. I own my own body shop and have been building cars and trucks for a long time.
good luck mate!
keep it clean and.....
......don't drive it in the rain....lol easier said than done I know. Also when you wash it use spray on cleaner like Final Inspection from McGuires for example.
The less water your truck ever sees the better.
good day mate!
#28
#29
#30
It really depends on what panel you are talking about. And where the rust is.
It also really depends on what you are building. If it's a show truck then replacing the panel is probably the best bet. If you are building a driver then do this:
If the metal isn't too thin you can clean it up the best you can and then use a rust converter on the panel to keep it from getting any worse. Hit it with a coat of primer and filler to smooth it out.
If it's a floor pan or something similar then a product like POR-15, Rust Bullet, Bill Hirsch Miracle paint, etc. will work and keep it from getting worse.
