Tierod ends
Old Feb 17, 2011 | 10:20 PM
TND's Avatar
TND
Tierod ends
Nevermind the rust in the picture.
I think this thing got pulled out of being stuck by the steering linkage. How hard is it in put in new tie-rods ends? The other side looks ok, think I should do both anyways? I was thinking of getting new sleeves too, to be nice to the mechanic that will be doing the alignment.
Old Feb 17, 2011 | 11:46 PM
donnor's Avatar
donnor
Tie-ing one on & Re-tiring...
Tie rod end replacement is fairly straightforward. Proper tools are needed including a pickle fork to remove the old ends. Just be sure to count the number of rotations to remove & that will give you a good starting point for the initial setup of your new ends & the trip to the alignment shop.
Also, by the looks of the cracks/weather checks in the sidewall of that tire I hope you are also shopping for new rubber.
dn.
dcassidy
Aug 20, 2009 10:48 PM
Stangfire
1997 - 2003 F150
Feb 24, 2007 08:40 AM
RawPower
Feb 21, 2005 09:49 PM
55forder
May 5, 2002 06:46 PM
