General Automotive Discussion
Stalling olds...mobile
Old Feb 17, 2011 | 07:17 PM
the_hetz's Avatar
the_hetz
1234567890
Old Feb 17, 2011 | 10:39 PM
Ford_Six's Avatar
Ford_Six
Coolant temp sensor, most likely. It's probably telling the computer the engine is much hotter than it is and going too lean to run properly.
That or your fuel tank isn't venting. Try running it with the gas cap off to rule that out.
Old Feb 18, 2011 | 06:52 AM
fellro86's Avatar
fellro86
Cat converter is a possible problem as well, since it is limited on revs. When it loses power, can you back off the throttle, and it feels like it picks up speed a little? Can you feather the pedal to get it to speed up? (back in and out of the pedal to get it going)
Old Feb 18, 2011 | 12:26 PM
jimandmandy's Avatar
jimandmandy
Since it runs ok for 10 miles or so, its a long shot. How about the fuel pump, does it make a lot of noise as it heats up like many GM pumps do?
Old Feb 18, 2011 | 10:08 PM
notyettoday's Avatar
notyettoday
My money is on either Ignition module or cat converter. It might be worth unplugging the intake air temp sensor to rule it out.
Old Feb 19, 2011 | 09:43 AM
the_hetz's Avatar
the_hetz
Old Feb 19, 2011 | 10:17 AM
F-series Fan's Avatar
F-series Fan
Even a newer cat can have issues, I'm leaning more toward a cat problem, It will probably put your CEL on when trying this but when it starts to do this again leave the engine on and loosen your fuel cap, if it resolves the issue than it is vapor-locking (just a simple test) Let us know how it goes
Old Feb 20, 2011 | 08:01 PM
Phinxter's Avatar
Phinxter
sounds like an exhaust restriction too me. Doesn't matter that you just put a cat on a while back. I have a pressure gauge that you screw into the O2 sensor bung to measure back pressure but a real redneck way of diagnosing this is to just remove the cat and drive it down the road. If this is the case you need to figure out what caused it to plug before you lay down the bucks for another one.
Old Feb 20, 2011 | 08:05 PM
fellro86's Avatar
fellro86
Probably should ask which motor we are dealing with here, 3100 or 3.4 DOHC?
Old Feb 21, 2011 | 10:10 PM
the_hetz's Avatar
the_hetz
Old Feb 22, 2011 | 07:44 AM
fellro86's Avatar
fellro86
Once plugging, temp is not as much of a factor, as it is an exhaust restriction at all times. The computer can try to adjust to deal with it, but can't totally compensate. Does it lack for power, then if you back off the throttle a bit, it seems to pick up? A lot of times they start out good, then choke up.
Old Feb 27, 2011 | 01:56 PM
the_hetz's Avatar
the_hetz
Old Feb 27, 2011 | 03:37 PM
Phinxter's Avatar
Phinxter
Thats weird on a 96 it should have set a check engine light. My 93 plymouth had a O2 go bad, it would idle fine and then when I took off from a light it would sputter, puke black smoke, then go into open loop and run fine until I came to a stop again. I got 17mpg on the hwy when I would normally get 28
Old Feb 27, 2011 | 04:26 PM
the_hetz's Avatar
the_hetz
ddinnan9
47
Mar 9, 2019 08:36 AM
DylanParker
1997 - 2003 F150
Oct 30, 2013 12:19 AM
jeromy_d2003
Feb 23, 2010 11:14 PM
SilverBullet131313
24
Jan 6, 2010 01:16 PM
FTK560
4 Cylinder Engines
Mar 28, 2005 01:35 PM
