help with lights on my dash
Old Feb 17, 2011 | 07:13 PM
gozu81's Avatar
gozu81
Hello everyone, i would like
to know if someone have any experience
dealing or troubleshooting with the lights
on the dash, so far i just check the bulbs and the fuses, and
seems to be ok, if someone have suggestions or any ideas i will appreciate
your cooperation, my ride is a 77 ranger xlt.
Thanks in advance for read this.
rgds.
Old Feb 17, 2011 | 07:56 PM
kentucky19's Avatar
kentucky19
Alot of times the plastic piece they go in gets brittle and they dont make good connection, however if its all of them its probably not that. I would GUESS its the headlight switch, keep twisting the **** back and forth and see if they do anything.
Old Feb 17, 2011 | 07:58 PM
2leadfeet's Avatar
2leadfeet
This may sound like a no brainer but did you try the dimmer switch? rotate it counter clockwise to make the lights brighter. Also you may need to clean the printed circuit board, with electrical contact cleaner. Also check for a bad ground.
Old Feb 17, 2011 | 09:25 PM
gozu81's Avatar
gozu81
well i think i may go with the bad ground ,cause none of them work, and the
head light switch seems to be working ok.
however i notes that when i start the truck the light that shows the parking brake shows up, and then goes down when the engine starts.
Old Feb 18, 2011 | 03:14 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
That light is for your service brakes, not your parking brake.
It comes on for you to check the light when you start it. If it comes on at any other time except momentarily when you start the truck it means there is a problem with your service brakes, and do not drive the vehicle as imminent brake failure can occur.
Check the fuse in the fuse panel for the dash illumination.
Old Feb 18, 2011 | 08:00 PM
gozu81's Avatar
gozu81
Got it,
Like i said i will check the fuses again, the ground, and i will go to the
junkyard and see if i cant get a headlight switch, just in case.
thanks everybody, and if someone have anyother ideas or suggestions
dropped here please.
kind regards
Old Feb 18, 2011 | 10:15 PM
The Confederate's Avatar
The Confederate
You could have a bad printed circuit. If none of the above fix your problem, dive in to your dash and check out the back side of the gauge cluster.
Old Feb 18, 2011 | 11:03 PM
Shooter00's Avatar
Shooter00
I fought mine for a while, turned out to be the brittle plastic like Kentuck19 said. It didn't look broken or worn, and the bulbs still locked into place. They just didn't lock tight enough to make good contact with the board. The way I figured it out was putting a test light into the back of the harness with everything connected. You can do a search and find wiring diagrams, that way you'll know what needs to be hot in the harness. Jeff's Bronco Graveyard had the new back housing, fixed mine right up.
Old Feb 18, 2011 | 11:58 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Once you get it fixed, if you have to pull your cluster out great time to change over to LED bulbs, brighter and last way longer.
Super Bright LEDs ? LED Lights, Bulbs, and Accessories
Old Feb 19, 2011 | 12:46 PM
bfktwb4's Avatar
bfktwb4
The headlight switch is multifunctional. It not only works the headlights, tail lights, and parking lights but also contains the dimmer circuit for illumination of the dashlights. Usually the dimmer rheostat portion of the headlight switch will open causing a no voltage condition to the PC board that delivers the juice to the dashlight (backlight) illumination bulbs. The headlight and parking light portion of the switch can still be functional. Assuming the ground(s) to the pc board are ok replace the headlight switch. Remember the other lights on the dash (idiot lights, if applicable) are on their own seperate circuits. Go to the parts store not a junkyard. The switch is cheap usually less that $30 depending on application.
Old Feb 19, 2011 | 07:44 PM
kentucky19's Avatar
kentucky19
Do they make a very big diference?
Old Feb 19, 2011 | 08:40 PM
77&79F250's Avatar
77&79F250
YES a big difference, from what I have heard on here. I will do the swap when the time comes.
Heard nothing but good things about it.
Old Feb 19, 2011 | 09:47 PM
FordmanShane's Avatar
FordmanShane
LED is blinding bright haha, but have you seen the shadow LED casts?
Old Feb 20, 2011 | 03:33 AM
77&79F250's Avatar
77&79F250
So are you saying it NOT a good idea? At last replace the wiper/headlight sw light with a LED so you can see it.
Like I said, from what I have heard on here its a good thing.
Old Feb 20, 2011 | 06:21 AM
qbenplaya00's Avatar
qbenplaya00
i would go with the leds if they are in a good position... i have 2 friends went with them... one has an old chevy pick up and it was good for him my other friend had an el camino and not so good too bright and cast shadows he would have to turn down the dimmer... but other then that its a good upgrade to the stock old 30 something year old system.
hey btw i am interested in this subject since mine dont work either! lol
