Seen above are my rad support bushings and problem. This is on my 1976 F-250 2wd with a 460. You can see my door lines are off and the bottom of the door rubs the fender. I have read that this problem is due to worn out rad support bushings. I measured the gap bewteen the bottom and the frame and it is not showing a low measurement since its suppose to be between .83" and 1.25". Whats wrong here and how do i fix my door gap issue?
So what is the condition of the bottom of the fender at the rear? What is the condition of the door and door hinges? Does not look to me like the radiator supports are compressed that much. How about the cab mounts? How about the radiator support itself? They are known for rust and falling down around the frame.
