ARP STUD TORQUE ?
Old Feb 17, 2011 | 06:04 PM
GSlahor's Avatar
GSlahor
ARP STUD TORQUE ?
The instruction that came in the box of brand new ARP studs for the 6.0 says to torque them to a final torque of only 80 ft-lbs ! !
I've read here on the forum torque values of 200+ ft-lbs for the ARP studs.
What gives ? Anyone know why the low value ? Is it because they are now sending some of their own lubricant to use on the nuts & washers while torquing ?
80 ft-lbs sounds low for a high strength 7/16" stud.
TIA................Gary
I'll probably call APR in the AM, but thought I'd poll the readers here first.
Old Feb 17, 2011 | 06:28 PM
Maxium4x4's Avatar
Maxium4x4
Depends on the lube that come with the set, yes, call ARP. Someone may have inserted the wrong information when packing.
Old Feb 17, 2011 | 06:31 PM
cheezit's Avatar
cheezit
gary my box said 210ftlb.
torq in 3 stages. 70 ftlb, 140ftlb, 210ftlb
contact arp and tell them before someone that is clueless screws up something important.
Old Feb 17, 2011 | 06:52 PM
broncoformudv's Avatar
broncoformudv
Just did mine last month and they said the same thing as cheezits did.
80lbs would cause someone some serious issues real quick!
Old Feb 17, 2011 | 07:30 PM
GSlahor's Avatar
GSlahor
Thanks for the replys. I'll definitely call ARP.
80 ft-lb just didn't sound right
Old Feb 17, 2011 | 10:42 PM
cartmanea's Avatar
cartmanea
Are you sure that spec was the for the head studs and not the rocker box bolts? The new ARP spec with their better assembly lube is 210 ft-lbs.
Old Feb 18, 2011 | 06:14 AM
2006powerstroke90's Avatar
2006powerstroke90
Yupp in the process of doing mine now, 210ft lbs is right.
RacinNdrummin
52
Dec 9, 2016 11:24 AM
frdf250
Jul 10, 2016 10:44 AM
jlo84truck
Jul 15, 2010 06:58 PM
Brown Falcon
21
May 17, 2010 09:06 AM
Stone Mathews
Modular V8 (4.6L, 5.4L)
Mar 21, 2008 08:52 PM
