lug pattern
Old Mar 12, 2003 | 08:52 AM
snowfighter's Avatar
snowfighter
lug pattern
Is the lug pattern the same on a 97 f250 as a 79 f250? Are the rims interchangeable?
Old Mar 12, 2003 | 09:02 AM
Sycostang67's Avatar
Sycostang67
lug pattern
Isn't 97 the year the F-250 started using those 7 lug wheels?
Old Mar 12, 2003 | 10:27 AM
McGinty's Avatar
McGinty
lug pattern
1997 Ford went to a metric pattern on the F150 from the previous 5 on 5 1/2" pattern that they used for over 30 years. I'm not sure when the changeover was for the bigger trucks. I changed mine out to a 5 on 4 3/4" pattern to accept aftermarket wheels.
Old Mar 17, 2003 | 12:21 PM
85 F250 W/ A 472's Avatar
85 F250 W/ A 472
lug pattern
To my knowledge the 97 3/4 tons had the same pattern all the way down to......when ever they should work. i think it was 98 or 99 when they went to the 7 lug light duty 3/4 tons.
dan
Old Mar 17, 2003 | 12:34 PM
Bleed Blue's Avatar
Bleed Blue
lug pattern
The F250 Light duty ran from 97-99. In 2000, the 250 distinction was pulled and it became an F150 with the 7700 weight package.
I don't think the 7700 F150s have the 7 lug wheels, but I could be wrong.
Old Mar 17, 2003 | 06:34 PM
78f250lj's Avatar
78f250lj
lug pattern
I researched this before and this is what I have found:
1997 the F150 went to metric. Any pre-97 F150 rim should have the same pattern as a earlier truck
1999 the F250/350 went to metric. Any pre-99 f250/350 rim should fit.
I am not sure about offset and backspacing though...... If I am wrong on the above, please correct me.
Lenny
Old Mar 17, 2003 | 07:29 PM
snowfighter
lug pattern
Thanks for all the help. Passed on the rims this time but now I know for sure.
