Water pump need HELP ASAP
Old Feb 24, 2011 | 07:57 AM
greg213187's Avatar
greg213187
Yeah I am pretty sure from the looks of things its just jammed in the timing cover (hopefully) due to the idiotic design of putting steel through aluminum. So the plan is to really try working the studs out, if they break cut the timing cover away and hopefully the planets align and the threads come right out of the block.
Old Feb 24, 2011 | 08:27 AM
deeznuts822's Avatar
deeznuts822
I was unsure which bolts you was talking about. Heat and pb blaster have never failed to get a frozen bolt loose for me yet.
Old Feb 24, 2011 | 02:54 PM
greg213187's Avatar
greg213187
It is the very top two left and right side on the water pump that go through the case into the block.
Old Feb 25, 2011 | 02:26 AM
TexasGuy001's Avatar
TexasGuy001
Once you get them out, you can get new bolts in the HELP section at Most autoparts stores. Dorman makes them. 23744
Dorman Products - 23744
Old Feb 25, 2011 | 05:24 PM
greg213187's Avatar
greg213187
Yep grabbed two kits today. Just wnated to let everyone who gave advice know I did get them out without issue yesterday. The Mapp gas and PB and time worked out. I only hope now there wont be any issues from the small holes I drilled above the studs in the timing cover. Thanks again guys!
kkrapp
May 1, 2013 09:07 AM
DBGrif91
Feb 26, 2011 03:07 AM
kaduh
Nov 17, 2009 04:08 PM
luke_trash
Apr 19, 2005 07:52 AM
Super Steve
All Things Towing
19
Jul 2, 2004 10:40 AM
