Tires for 99 F250 235/85R16 or 265/75R16
The tires on my '99 F250 SC/LB 4x4 have not treated me well this winter and seem very unresponsive on the highway, but that might just be that I'm too used to my car. I also realized that the tires are Load Range C instead of D or E.
Currently I have LT265/75R16 Goodyear Tracker 2's, which came on the truck when I bought it. 3 of the 4 tires look to have plenty of tread and 1 (right rear, guess my LS isn't working so well) is not as good.
2 of the reasons I bought this truck because my old 1/2-ton seemed to always be overloaded, and I wanted 4X4 in the snow. I don't do much towing though. I'm leaning toward the 235s thinking I'll get a little better gas milage and generally wider is not better for snow, but if the 265 gave me a little better feel and better performance under load, i would probably go that way. This isn't my daily driver, so noise and ride aren't major concerns for me.
What advice can you give me?
Thanks,
Kurt
Thanks,
Kurt
265 75 16 is the factory size. 286 75 16 is the max size... but I think other have gone a bit larger with very little if any rubbing on tight turns.
Definately get the E rated tires especially if you are going to haul any loads. They have more sidewall strength for better handling under load.
If you aren't going to haul that much weight you can get away with D rated but they will be a little squishy when under load and feel odd.
235's? Now thats a scrawny tire. Must of looked odd.
My 04 F250 4x4 XL came stock with 235x85R16 E's and did well in snow and handling. I would not advise you to use a load range C rated tire on your truck. The 235's should give you a very small improvement in fuel mileage over the 265's too, primarily because of less rolling resistance. If it were me, based on your useage, I would use the 235's primarily because of fuel mileage, tire costs and traction in snow.
The 235's get lost in the wheel wells. I would stick with the 265's, you're not going to get any better mileage going to the 235's.
To the OP. My truck came with 235/85/R16 E tires from the factory. They did ok in the snow on road, but offroad forget about it. They were horrible on the highway even with lowered air pressures. Every bump threw the truck around and jerked the steering wheel. I since went up to 285/75R16s which are little over 1" taller than the 235/85s but are a minimum 2" wider. Traction, handling and steering feedback improved dramatically in all situations. With that said between the two sizes you listed I would go with the 265/75R16 tires as they are slightly wider than the 235/85s but have a diameter almost the exact same diameter. The truck will be a little more stabill due to the wider contact patch. If you get a decent tread design on the 265s they will work very well during the winter. I just prefer 285/75R16s and am never going back to either of the 265 or 235.
My truck came with the same tire but it was a little different name back then. They wore good and the tread pattern gripped half decent for what they were but as I said before they were brutal on a bumpy highway.
Indeed, they are terrible. I get thrown around everywhere, my friends 99 f350 v10 with 265/75s rides much better
