Slave Cylinder
Old Feb 16, 2011 | 05:33 PM
circllb's Avatar
circllb
Slave Cylinder
On a 1984 Ford 3/4 Ton Diesel. Can someone help on where the Cylinder is and is it easy to get to. I don't know if that is the problem but was told to start there.
Thanks
Old Feb 16, 2011 | 05:42 PM
Shark Racer's Avatar
Shark Racer
I'm assuming you're not able to release the clutch?
The slave cylinder is on the driver's side of the transmission. Pretty easy to see, will have a single black hydraulic line going to it and is mounted on an ear of the bellhousing.
I'd check for firewall flex by having someone pump the clutch pedal while you view the master cylinder in the engine bay.
Old Feb 20, 2011 | 01:19 AM
Connie_Marie's Avatar
Connie_Marie
As far as I know..all the 84's came stock with a sealed non bleedable clutch master and slave system.... You can get replacements with bleeders on the slave. mine has a RED line running between the master and the slave
Old Feb 20, 2011 | 01:30 AM
dmanlyr's Avatar
dmanlyr
The 1983's also had the same, at least on my 83' diesel w/ a t-19b. At the time, I could not find anything aftermarket like what you have found, but I would be concerned that at least on mine, all the hydralic clutch stuff looked pretty cheaply made... You might find out that you will end up replacing both items in the long run.
OP - Other than that, I did my clutch work way back in 1986 so I don't remember the exact color of the line, but I am pretty sure it was not black, on that 83'. So all I can offer is to second what was said, it is on the side of the bellhousing (flywheel casing for our overseas viewers).
David
Old Feb 20, 2011 | 11:03 AM
Shark Racer
FYI, I never cracked the "bleeder valve" once when replacing my hydraulic setup.
Old Feb 20, 2011 | 11:21 AM
Franklin2's Avatar
Franklin2
Most of them do have a bleeder, but it's hard to see. It's a set screw on the slave that takes a 5/32 allen wrench. But you are correct, this only seems to get fluid through the system, it doesn't do much for getting the last bit of air out. Time and use seems to do that, as the air slowly works it's way up to the clutch master on it's own as you drive it.
Navistar
2004 - 2008 F150
May 20, 2003 10:28 AM
myst
Mar 30, 2003 01:34 PM
FlowmasterMan
4 Cylinder Engines
35
Dec 27, 2002 08:03 PM
gustafson
Oct 13, 2002 09:15 PM
Jul 14, 2001 06:50 PM
