Transfer case Oil change?
Old Feb 16, 2011 | 02:51 PM
thekiwi's Avatar
thekiwi
Anybody changed the fluid in their transfer case yet? I was planning on changing it just so I know its clean. I believe it takes ATF.
Old Nov 29, 2020 | 05:20 PM
speakerfritz's Avatar
speakerfritz
depends on year model
Old Nov 29, 2020 | 05:55 PM
Overkill2's Avatar
Overkill2
I know for the 11 to 16 it was the XL12 fluid for the transfer case. But they don't make it anymore. It was super seceded by Mercon LV. My next upcoming change will be with Mercon LV.
Old Nov 29, 2020 | 08:48 PM
HRTKD's Avatar
HRTKD
Save your money. ATF in the transfer case is just fine. The transfer case is a lot simpler than the transmission.
Old Nov 30, 2020 | 12:43 PM
buba 11's Avatar
buba 11
I went to my local dealer to get the xl12, they didn't have it. The parts guy talked to the truck service manager who told him to give me mercon V. come to find out this makes the clutches in the auto 4wd fall apart because it softens the GLUE AND THE CLUTCH FACING FALLS OFF!! So the latest ford doc says use mercon LV, same stuff in the tranny. So being totally confused, I went to autozone and bought some synthetic valvoline equivlent of the XL12. Not cheap but it seems to work well
Old Nov 30, 2020 | 12:47 PM
ford390gashog's Avatar
ford390gashog
The XL12 is discontinued, there also is no worry about clutch failure in these units because its never been used in these trucks.
Old Nov 30, 2020 | 09:07 PM
FishOnOne's Avatar
FishOnOne
As long as it's not Mercon V or any knock off. As Overkill2 has stated I would stick to Mercon LV.
Old Dec 1, 2020 | 08:24 PM
Overkill2's Avatar
Overkill2
I just did my transfer case and trans today at 67147 miles. Last change was 35697 miles ago. I believe in the 30k mile OCI for the case and trans. Not a great day to do it as it was cold and snowing but not too hard at that time.
There were some visible flakes of metal from the transfer case which I did first, drained that is. I had about half a quart or so of the XL12 oil so I used that with the Mercon LV that I had on hand. I did confirm with my dealer before that the XL12 was phased out as they now list Mercon LV for the transfer case.
The last trans drain and fill, I dropped the pan and did a filter also. I cleaned up all the break in material from the donut magnet that is in the pan. This time I just drained and filled. Another 30k miles, I'll drop the pan to change the filter.
EDIT
And remember, get 3 quarts for the transfer case. It's just over 2 quarts at about 2.25 qts.
Old Dec 2, 2020 | 05:36 AM
senix's Avatar
senix
I run a 60K schedule for rear diff, trans and transfer case. Usually do a coolant flush too, but with this new 2020 and the change in coolant, I may just extend the coolant change interval.
Old Dec 3, 2020 | 03:19 PM
Overkill2's Avatar
Overkill2
You work your truck way harder than I do Scott. When my truck was in under warranty for DEF heater and locking hubs, I had them check the coolant. All was good.
I can see myself doing a change over to the yellow in the future for sure.
Old Dec 13, 2020 | 11:34 AM
jimmystoys's Avatar
jimmystoys
What's the suggested interval change on the transfer case?
Old Dec 13, 2020 | 12:17 PM
senix's Avatar
senix
I do mine @ 60K and the rear diff and trans too.
Old Dec 13, 2020 | 01:03 PM
Overkill2's Avatar
Overkill2
I'm sure it's the same as the trans at 150k miles but that's bunk IMO. But what do I know. There's no way I'd wait that long. Scott gives a good OCI there. And he works the snot out of his...
I side on the fact that a case of Mercon LV is cheap and I'm overkill.
Old Dec 14, 2020 | 11:46 AM
dirthawg's Avatar
dirthawg
I'm going to go with 50k changes for the same reasons as Dave, Mercon LV is cheap compared to a new trans or transfer case.
Here are some snippets from the 2016 owners manual. Take your pick or make up your own.
Old Dec 15, 2020 | 12:58 PM
HRTKD's Avatar
HRTKD
From the 2017 Owner's Manual:
Axle and Transfer Case Maintenance
Axle(s) and transfer case (4X4 only) fluid
changes or level checks are not required
unless a leak is suspected or the assembly
has been submerged in water. During long
periods of trailer towing with outside
temperatures above 69.8°F (21°C) or at
wide-open throttle for long periods above
44.7 mph (72 km/h), change the rear axle
fluid every 30,000 mi (48,000 km) if the
rear axle is filled with non-synthetic fluid.
This interval can be waived and the
150,000 mi (240,000 km) service interval
can continue if the rear axle is filled with
75W140 synthetic gear fluid meeting Ford specification...
I have plenty of gear lube and ATF sitting on the shelf, so I'll be doing a change at 30K. Most of the miles on my truck are towing.
mr.noodi
Jul 30, 2015 06:19 PM
yeldarb82
Sep 22, 2009 08:35 PM
kona56
Sep 9, 2009 07:08 PM
silly34
May 22, 2009 08:10 PM
pcguy760
Nov 16, 2008 09:03 PM
