transfer case oil
Old Sep 22, 2009 | 02:59 PM
yeldarb82's Avatar
yeldarb82
transfer case oil
what oil goes in the transfer case
Old Sep 22, 2009 | 04:38 PM
maverick1701's Avatar
maverick1701
the x-fer case runs ATF
here is a link where they go into more detail
https://www.ford-trucks.com/forums/8...ml#post7524402
Old Sep 22, 2009 | 07:37 PM
pjwoolw's Avatar
pjwoolw
Use a good synthetic of your choice. Check to see how much metal comes out with the fluid. Give the truck a good run before you change it. If you see metal change the fluid again after a few months.
Old Sep 22, 2009 | 07:48 PM
yeldarb82's Avatar
yeldarb82
no metal that i could find the fluid was black as night but smelled like tranny oil so i thought i would ask. Do i have to split the case to change the yoke bearing and input beaing on these t cases
Old Sep 22, 2009 | 08:16 PM
pjwoolw's Avatar
pjwoolw
I would think so. I can't see any other way to change the bearings. But I have no personal experience.
Old Sep 22, 2009 | 08:35 PM
yeldarb82's Avatar
yeldarb82
If some one could do me a huge favor and test the connector to map sensor and let me know what they get i have two 5v in one ground when the trucks off the ground is solid but when the truck is running the ground pulses. I am just trying to chase down a map sensor /power problem when its plugged in. It would be much appreciated.
