How much Coolant
Old Feb 16, 2011 | 12:48 PM
north2south006's Avatar
north2south006
How much Coolant
I have a 2003 with the 6.0 How much coolant do I need. Local shop told me 27quarts or just under 7 gallons does this seem correct? I thought it was a little high.
Old Feb 16, 2011 | 01:23 PM
dchamberlain's Avatar
dchamberlain
That's about right. If you're doing a flush, 3.5 gallons of concentrated coolant and add water gets you about 7 gallons of 50-50 mix.
bismic's Avatar
bismic
They are correct as to the system capacity. Depending on what you are doing, you might not want to buy 7 gallons of 50/50. A lot of coolant stays in the block - even if you remove the block drain plugs. If you THOROUGHLY flush w/ DI water, you will leave quite a bit of DI water in the block. The best thing to do is buy 4 gallons of 100% coolant and add 3 1/2 gallons of it to a system that has ONLY DI water left in it. Then top off w/ DI water.
Fill the left-over 1/2 gallon w/ DI water so you have a gallon of 50/50 for times you might need to add a little.
edit ...............
Your are fast today David!!!
Old Mar 5, 2020 | 03:13 PM
Nlmb Dilo's Avatar
Nlmb Dilo
ok one last thing when I changed the thermostat I added 2 gal of 100% coolant. Should I still flush?
QUOTE=bismic;9976656]They are correct as to the
Your are fast today David!!![/QUOTE]
Old Mar 6, 2020 | 01:42 PM
FiveOJester's Avatar
FiveOJester
Old Mar 7, 2020 | 09:30 AM
F350 1990's Avatar
F350 1990
Excellent recommendation from FiveOJester (remember to keep one eye closed tightly or you won't see the colors, scale properly) and I'd also check electrolysis as diesels are vulnerable.............
Old Mar 7, 2020 | 01:10 PM
TooManyToys.'s Avatar
TooManyToys.
I have a refractometer too, they are good at what they do.
corksil
Mar 7, 2020 04:39 AM
sbraatz
Nov 1, 2016 07:33 PM
02GrayPowerStroke
Mar 1, 2010 03:05 PM
AndeyHall
Nov 21, 2009 07:14 PM
Lennyg
1997 - 2003 F150
Oct 16, 2008 10:53 AM
