Sponsored by: Real Truck
Tire size calculator
Old Feb 16, 2011 | 11:45 AM
Wagion's Avatar
Wagion
Was looking for what actual diameter of tires where and found this.
Old Feb 16, 2011 | 12:15 PM
Kajtek1's Avatar
Kajtek1
This doesn't show actual diameter, but the theoretical one. I found 2 different models of tires, coming from the same manufacturer in the same nominal size having like 12% difference in rolling diameter.
The only real thing is to find rpm (rounds per mile) for the actual tire on manufacturer data sheet.
Old Feb 16, 2011 | 03:59 PM
89LX306's Avatar
89LX306
By rolling diameter do you mean with the tire on the ground as opposed to off the ground? That is what I have heard of as rolling diameter. Not sure how accurate.
However...12%? That is huge! on a 30" tall tire that is over 3.5" of difference. That is no longer a 30" tire...that is a 33". What tire manufacturer are you referring to?
Old Feb 16, 2011 | 05:24 PM
Kajtek1's Avatar
Kajtek1
Measuring tire "working" diameter is tricky business.
Tires flex with inflation and load, meaning with bigger load the same tire is going to have smaller rolling diameter. Than at speeds the centrifugal forces change the rolling diameter as well.
That didn't matter in the past, but now ABS, traction and ESP systems are having speed sensors at each wheel and when one tire spins with different rpm, it will take it as lost traction. Usually the systems give you 3% tolerance before kicking warning lights.
So if you are matching different tires, you have to go to the tire data sheet and read the rpm. The manufacturer doesn't matter >>> all of them manufacture tires with pretty loose tolerances.
Old Feb 17, 2011 | 10:29 AM
89LX306's Avatar
89LX306
I was just curious what particular model you were referring to.
I'm well aware of the havoc tires can play on newer vehicles. Take a look up in the Expedition forum and you will see problems with worn different tread depths (same model/size tire) on the Expedition AWD models. You really have to watch what you do or sensors will quickly let you know they didn't like it.
Budlight592
6.7L Power Stroke Diesel
Mar 28, 2014 08:10 AM
pancake
Nov 8, 2009 03:37 PM
Darth Baiter
Dec 3, 2003 03:33 PM
