Exhaust question
Old Feb 15, 2011 | 10:39 PM
Steelheader87's Avatar
Steelheader87
Exhaust question
I am considering straight piping my pick up. It has a banks turbo and 3" back to the muffler and 3 1/2" coming out of the muffler. I will I notice any performance gains if I cut the muffler out? How much louder will it be with it being straight piped? Will I see any difference in MPG's by doing this? Thanks in advance for your input.
Old Feb 15, 2011 | 11:27 PM
fordhorse's Avatar
fordhorse
i don't know what kind of gains you may pick up but i like the way my truck sounds its not all that loud the turbo acts like a muffler and you can hear the whine more
Old Feb 16, 2011 | 02:31 AM
Aune163rd's Avatar
Aune163rd
He is right on the turbo part, it does muffle the sound of the engine, i had a straight piped N/A when I got the truck. I hated it, it was incredibly loud and made too much noise. It depends if your muffler is a straight through or not, there are no power differences that i have noticed from what my buddy with the Banks turbo-charged 7.3 says. If you do straight pipe it, i would go with 3.5" all the way back because as we all know the more this engine can breath out the more it can breath in. These trucks love air and there is always someone tinkering with things to figure out how to give them just that. More and more air.
Old Feb 16, 2011 | 03:19 AM
91dirtydiesel's Avatar
91dirtydiesel
My n/a truck is straight piped and I love it. Very loud when you get in it
Old Feb 16, 2011 | 08:22 AM
mabc926's Avatar
mabc926
I have a straight pipe turbo 7.3, and I think it sounds fine.
As for power gains, I don't think cutting out the muffler will do much, and I don't think going bigger than 3" pipe will give you any extra power either, it'll just make your exhaust sound deeper.
Old Feb 16, 2011 | 08:25 AM
snaponprofile's Avatar
snaponprofile
I have a banks turbo and I have a 3.5 inch dynomax straight through muffler that does the trick. Loud enough to hear the turbo whine and diesel engine but yet quiet enough so you eardrums never hurt.
Old Feb 16, 2011 | 08:27 AM
snaponprofile
Mabc, with a turbo, going larger than 3 inch helps. With n/a, it doesn't.
Old Feb 16, 2011 | 08:47 AM
mabc926's Avatar
mabc926
How much gain do you get going for 3" to 3.5?
I can tell you, nothing.
I'm not saying bigger pipe is bad, but 3" is just fine.
I remember when everyone with a diesel truck got huge stacks cause they added so much power
Old Feb 16, 2011 | 09:15 AM
wreckinball's Avatar
wreckinball
my current na setup is the dual three inch off the manifolds to a single 4 inch with a five inch tip as you can see from my sig. It has the straight through muffler so if you want to go striaght piped performance and tone that nasty rattle down at high rpm's, get that muffler. My exhaust will stay the same just that off the down pipe it will go immediately to four inch pipe.
The 5" tip added so much horse power its crazy, highly recommend!!
Old Feb 16, 2011 | 10:36 AM
snaponprofile
When you want to increase fuel and air the the compression housing and still keep EGT's in a good place, you want absolutely no restriction for the DP. I'm not saying to put 5 inch stacks on, just saying when you want to tweak the turbo system for more power, the last thing you want is texhaust to be in the way. So to insure the exhaust will never be a problem, go 3.5 and larger. If you like high EGT's and lower than possible boost, stick with 3inch.
Psyclopse
Feb 4, 2012 02:35 PM
badasp118
22
Feb 28, 2011 02:02 PM
superv10
Aug 22, 2005 03:33 PM
mudfox26
Feb 8, 2005 11:03 PM
