1978 - 1996 Big Bronco
Speedo is dead
Old Mar 11, 2003 | 10:18 PM
Jeepincj7's Avatar
Jeepincj7
Speedo is dead
So is the odometer. This is on a 94' Eddie Bauer. The digital odometer and the speedo are dead and do not work. Any ideas? The rest of the dash lights and gauges work fine except fpr this stuff.
Old Mar 11, 2003 | 11:32 PM
steve83's Avatar
steve83
Speedo is dead
Get a Haynes manual and check the power, switched power, and ground circuits to the PSOM. Have you checked all the fuses thoroughly?
Old Mar 12, 2003 | 12:25 AM
Jeepincj7's Avatar
Jeepincj7
Speedo is dead
Haven't check anything yet, but have a feeling its speed sensor related. The tranny started doing "interesting" things. I'll check things out tomorrow night.
Old Mar 12, 2003 | 11:05 PM
steve83's Avatar
steve83
Speedo is dead
The sensor won't turn the odometer off - can you still see the numbers in the LCD? By "dead", I thought you meant NOTHING worked.
Old Mar 12, 2003 | 11:19 PM
Jeepincj7's Avatar
Jeepincj7
Speedo is dead
Ended up being a fuse. Why on earth would Ford make it so easy to simply pull a fuse to disable the odometer? That fuse works the dome light, speedo, and odometer, so essentially you could mask the mileage by simply unplugging the fuse.
Old Mar 12, 2003 | 11:21 PM
steve83's Avatar
steve83
Speedo is dead
It's the memory circuit for the whole dash - radio, courtesy lights, PSOM, clock, & a few others.
Abner
Jul 25, 2016 09:36 PM
farmer7
Jul 20, 2009 09:34 PM
eehoepp
Aerostar
Apr 27, 2007 02:15 PM
muscle66
Dec 1, 2005 07:32 PM
Ian Jenkins
Jul 7, 2003 01:20 PM
