Why did my motor blow?
Clay at RiffRaff has OEM BABY forged rod rebuilds.
http://www.riffraffdiesel.com/mm5/me...=F731-TRANS-FE
Being an '01, you might have the infamous powdered metal connecting rods that the '01's and up came with. The earlier 7.3L's had forged rods and were basically bomb-proof from what I've read. It seems to be a hit and miss deal with them... some stock motors blow and some ere running 500HP and have yet to die. When and IF you take it apart, it'd be interesting to see if you've got some broken connecting rods.
Very funny... y'all take me wrong!
Guys, I don't think that PMR's are the only problem. PMR's, IF the OP's are PMR's, just aggravate the problem. I'm sure if anybody tried hard enough, they could break anything! I'm just saying that if he had PMR's, it would explain his mess pretty well. As for the forged rods breaking, I'd have wonder about their tuning... from what I can tell, cylinder pressures seem to dictate whether or not the motor lives. I know tuning can determine whether or not PMR's survive... to screw up a forged rod motor, I would think there'd have to be some poor tuning involved. But what do I know? I just go by what I read... then I call up Clay and find out what holds water and what doesn't.
Well, my motor blew tonight. The rods got a breath of fresh air via the oil pan.
So I guess I'm looking for a different engine.
I'm kind of confused as to what caused this. I changed the oil regularly at 5,000 mile intervals, used John Deere 15w-40 oil, and always let it warm up before taking off. I did pull some heavy loads (14k trailer included) from time to time. I wasn't easy on it but wasn't abusive either. It had 169,xxx miles on it also, which I didn't think was much.
The only mods I had were air intake, 4 inch exhaust, and a dp tuner.
Did you normally drive around with the +80 tune, and tow with the +40 tune?
When did you install the DP, and did you ever have the tunes updated?
From what it sounds like, Jody updates his tunes regularly. But I've never heard any specifics beyond that, like if it's a set schedule, if he keeps track of what updates are made when, etc.
If you decide to tear down the engine, take lots of photos and notes about what you saw and where. I would look at the top side first and see if any part of the valve train is compromised and keep the parts organized by cylinder. Then later on when you get to the bottom end you can look at the valves and pushrods more closely if you suspect something weird.
Same for the injectors, keep them organized in case you discover something weird on the piston tops etc. I'd also be curious about the cooling jets and if any of them are missing. Good luck.
Just curious:
I'm not sure if I'm going to put another 7.3 in or fix up the body and do a cummins conversion. Going to do same calculations tonight.
#28
Just curious:
#29
A Cummins conversion would be sweet! I would take the motor apart first if you can and find out what caused it... if it was because of PMR's, then I'd drop in a built-up 7.3L and be done with it. I've got 303K on mine (forged rods) and I have yet to kill it! My live data checks out great and the only leak is an oozing oil pan seal.
