Code 52
Old Mar 11, 2003 | 09:24 PM
PigFarmer's Avatar
PigFarmer
Code 52
I'm getting a code 52- power steering pressure sensor staying either open or closed all the time. Any good way to test the sensor or just replace?? With the ohm meter I'm getting fairly high resistance. Does the sensor operate as totally open/closed or is does it have variable resistance. Can this be the reason I can't enter KOER.
Randy
Old Mar 11, 2003 | 10:32 PM
steve83's Avatar
steve83
Code 52
It's a switch, so its resistance should either be 0 or infinite. That code shouldn't keep you from running a test.
Old Mar 12, 2003 | 07:27 AM
PigFarmer's Avatar
PigFarmer
Code 52
Thanks Steve83. The switch must be stuck then.
The reason I asked about the KOER was that I was thinking that the procedure for entering KOER was to turn the steering wheel a half turn after the engine designation flash series. I stomped on the brake pedal also. I was assuming that the EEC was looking for that switch make/break and if the switch was faulty then it wouldn't see this. I'm getting the engine flash series (4 on my app) then nothing. Shouldn't I at least see a 1-1 if no codes are stored in this portion of the test? Is the EEC reading a different sensor when the steering wheel is turned?
Randy
Old Mar 12, 2003 | 09:21 PM
steve83's Avatar
steve83
Code 52
I haven't read thru Haynes recently, so I don't remember what you should expect or how to trigger KOER. Are you going by the Haynes?
Old Mar 12, 2003 | 10:22 PM
PigFarmer's Avatar
PigFarmer
Code 52
I'm using Chilton's. I think it said that models utilizing the power steering pressure switch (which mine has), then the steering wheel had to be turned at least 1/2 turn within 2 seconds after the engine designation code flashes. If I remember right, if it didn't have this switch then stomping on the brake pedal would activate the test. I did both to have all the bases covered. I've got a new switch on order.
Randy
Gene W
Oct 29, 2013 10:03 AM
RKraft
Sep 7, 2013 08:53 AM
rhoward
Jun 22, 2013 08:22 PM
drunkdave
1978 - 1996 Big Bronco
Jul 14, 2011 12:06 PM
