Sponsored by: Real Truck
Leveled 2wd steering issues
Old Feb 15, 2011 | 06:57 AM
drmeece's Avatar
drmeece
I installed 2.5” spacers under the front coil springs on my 04 f250. Re used the old shocks. Had the truck aligned they installed new camber bushings. Drove the truck home and steering darts, had bump steer and when turning left or right the steering wheel didn’t want to come back to center I would have to pull it back.
Took the truck back to the alignment shop they loosen the pinch bolts on the camber bushing a little and told me that the problem is that my upper ball joints are not moving because they are factory and non greasable and that in time they should move to where they need to be. ( sounds like a line to me but who knows). Anyway after this visit to the shop the steering is a little better but the problem is still there.
Has anyone else had these issues and what is the fix??
Thank you
Old Feb 15, 2011 | 07:30 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
I have a leveling kit on my 2wd, 03, F250 and I have no issues at all. I think they are feeding you a line, but I dont have any idea what might be causing your problem?
Old Feb 15, 2011 | 07:44 AM
drmeece's Avatar
drmeece
Did you put longer shocks on it when you installed the lift???
Old Feb 15, 2011 | 08:12 AM
Truck Paradise's Avatar
Truck Paradise
Sounds to me like they got the caster way off. Did they give you a print out of the alignment settings? If so let us know what camber, caster, and toe settings they used.
Old Feb 15, 2011 | 10:10 AM
drmeece's Avatar
drmeece
This is from the print out they gave me.
FRONT LEFT
CAMBER 1.1
CASTER 3.1
TOE 0.09
SAI 10.9
INCLUDED ANGEL 12.0
FRONT RIGHT
CAMBER 1.2
CASTER 3.1
TOE 0.01
SAI 10.4
INCLUDED ANGLE 11.5
FRONT
CROSS CAMBER 0.0
CROSS CASTER 0.0
CROSS SAI 0.5
TOTAL TOE 0.11
Old Feb 15, 2011 | 10:36 AM
Truck Paradise
As long as that's a +3.1 on caster, which it almost has to be, that blows my theory out of the water. Back to the drawing board.
Old Feb 15, 2011 | 10:55 AM
drmeece's Avatar
drmeece
[QUOTE=Truck Paradise;9970849]As long as that's a +3.1 on caster, which it almost has to be, that blows my theory out of the water. Back to the drawing board.[/QUOT
Yes it is....Thank you for your input...I was hopeing you were on to something.
What do you think about the shocks..It was tuff getting them back on. Too short maybe..
Old Feb 15, 2011 | 11:37 AM
Truck Paradise
Too short of a shock would give you a really jarring ride, don't think that's what is causing your steering binding. Is there another shop you could take it too for another opinion.
I was hoping I had an easy fix for you too.
Z3T3C
19
Aug 13, 2014 03:48 PM
KWIZ
May 11, 2014 08:38 AM
DSN46
Feb 22, 2013 08:10 PM
abelmoreno
Jun 23, 2005 10:57 PM
F150_Luvaa
Apr 6, 2002 08:59 AM
