GlowShift Gauges
Old Feb 16, 2011 | 05:35 PM
JOHN2001's Avatar
JOHN2001
I have a set too, they seem right on to me. The only problem i ever have is when it rains or the road is wet, my egt gauge drops to 0 then shoots back up, could just be something i did but i have no problems with the other ones. I got mine on ebay for under $200 with a painted pilar.
Old Feb 17, 2011 | 01:08 PM
ht99vpi's Avatar
ht99vpi
I think you guys just conviced me to buy them. I had been looking at gauge kits and when I came across glow shift I thought the price sounded to good. Thanks for the input.
Old Feb 17, 2011 | 01:22 PM
bcaughhorn's Avatar
bcaughhorn
I got mine with the pod on ebay for 200$ zero problems. I love them. They have a 1 year warranty
Old Feb 17, 2011 | 03:01 PM
Joe28443's Avatar
Joe28443
Joe28443
I want to put the boost tranny and egt over the mirror in a 3 pod. I there enough line for that? Or would I just have to order more?
Old Feb 17, 2011 | 04:06 PM
twayne85's Avatar
twayne85
No matter where you put them, you might want to consider getting a longer boost hose. Mine are under the dash so there was more than enough wire for that, not sure about above the mirror.
Old Feb 17, 2011 | 04:59 PM
7.3bo-ti-etr's Avatar
7.3bo-ti-etr
Ok so the Gauges work and look great, but I'm using my cell phone and no where does it show that I can insert a image. So how can I post some pics.
Old Feb 17, 2011 | 05:02 PM
bcaughhorn's Avatar
bcaughhorn
you will have to get more
Old Feb 17, 2011 | 06:33 PM
DeLorean623's Avatar
DeLorean623
I've got 'em in my '02 and my wife has them in her '97 OBS. For the money, they can't be beat. We've each been running them for about a year now with no problems at all. EGT, water temp, boost for me and EGT, trans temp, boost for her. Trans temp and water temp are the same, save for the lettering on the face. The colors being on all the time hasn't bothered me, I'm used to it with the aftermarket radio. The green isn't that far off from Ford Gauge Green either!
Old Feb 17, 2011 | 08:06 PM
Joe28443's Avatar
Joe28443
Joe28443
Thanks for the info
Old Feb 18, 2011 | 01:12 AM
01raptor's Avatar
01raptor
does the color of the gauge pod paint match up pretty good to the trucks interior. I have the grey interior and i see that ebay has a gauge and pod set with the pod already grey.
Old Feb 18, 2011 | 09:50 AM
n20's Avatar
n20
had them for 2 years and they work great. You will need a longer boost hose, and the wiring can be a little tough to get all stuffed behind the pillar but it can be done. I put an inline fuse between the positive battery terminal and the gauges on the constant 12v source line just in case. Also wired a switch in to turn off the constant 12v source when it is parked for long periods of time.
Old Feb 18, 2011 | 11:39 AM
moto_xxx_99's Avatar
moto_xxx_99
I run them too and they are great. The best way to wire them up is with an add a circuit. It is a circuit that will plug into where you have a constant 12v source in fuse box and a switched 12v source at fuse box. Local auto parts stores have them. There is no need to wire directly to battery. Wiring is very straight forward. Although if you have no experience with wiring, it may be a little tough.
Old Feb 18, 2011 | 08:34 PM
  #28
danskool's Avatar
danskool
Go Bills !
My dad has a grey interior. Got the grey pod and gauges from glowshift and they are almost a perfect match. Even if it was off a tad it should still look good. Grey is a easy color to blend in.
Old Feb 18, 2011 | 08:46 PM
  #29
JOHN2001's Avatar
JOHN2001
I have a grey interior and if its off its not enough for me to care, looks good.
activepat
Feb 23, 2017 09:28 PM
powerstrokin007
Dec 9, 2008 03:50 PM
daspud
Nov 25, 2002 09:47 PM
76RangerXLT
Garage & Workshop
Feb 17, 2002 04:53 PM
KPO
Offroad & 4x4
Sep 11, 2001 07:38 PM
