Baffled... 1990 5.0/E4OD problem, or problems?
Old Feb 14, 2011 | 05:54 PM
ratio411's Avatar
ratio411
Good idea on the solenoid connector.
That thing is so out of sight, out of mind that I forget it exists.
It's also buried under my exhaust too.
Hard to get to.
I see how that is a highly likely candidate for losing gears, but not starting???
Old Feb 14, 2011 | 05:55 PM
dustybumpers's Avatar
dustybumpers
Originally Posted by ratio411
I have no way to pull codes straight out.
There has been no "OD" light flashing (as my vans do when they throw codes) or CEL.
That was making me think PCM, as the PCM throws codes for almost everything but itself.
check the engine codes , they're in there. there is a way to do it with a paper clip, and count the cel flashes, that has been discused here , you'll have to do a search. I have a scanner, so I never tried it.
ratio411's Avatar
ratio411
Originally Posted by dustybumpers
the new switch is the better one, the old one will still plug in, the plug stayed same configureation, but became better, and waterproof
For the 1990 harness, I had to totally pull the truck side wiring apart and make a new weatherpack connector with a kit. They don't interchange, at least not my year model.
Old Feb 14, 2011 | 05:57 PM
dustybumpers
Hard to get to.
yeah, but not starting is definately the mlps. if you take a 8mm wrench, and remove the heat plate, you can get to the sol pk plug a lot easier. but it still bites your arm on the cat
Old Feb 14, 2011 | 05:59 PM
ratio411's Avatar
ratio411
I'll look it up. I have done the paperclip code check on GMs before, so I'll figure it out.
However, where can I get a code reader for a 90 EEC-IV?
Wal-Mart and the parts houses around here all stopped carrying them as "obsolete". They only sell the OBD2 versions now. They look at me like I stepped out of the stone ages when I ask for a pre-OBD2 code reader.
Old Feb 14, 2011 | 06:00 PM
dustybumpers
it goes 90-94, then 95 up. if you need the harness patch kit, call DACCO, at 1-800-443-2226,, they can also help guied you in the right direction.
Old Feb 14, 2011 | 06:01 PM
dustybumpers
bought mine at harbor freight for about $35. I have seen them at advance auto before.
Old Feb 14, 2011 | 06:26 PM
subford's Avatar
subford
The MLPS will not stop the spark.
Before going deeper go ahead and unplug the Computer and see if spark returns.
Might be a good idea to unhook the battery before pulling the plug on the computer.
The only code that may help you would be a PIP code and that would tell if the PIP is bad.
I would forget about the transmission until you get spark back.
Old Feb 14, 2011 | 06:37 PM
ratio411's Avatar
ratio411
Can it spark without the PCM hooked up?
I figured a good PCM hooked up was a must for ignition...
Old Feb 14, 2011 | 06:43 PM
subford's Avatar
subford
The PCM is not needed for the spark but can stop it.
So after you unplug the PCM leave it unplugged until you get spark back.
It will not run without the PCM hooked up as the injectors will not fire and the fuel pump will not run.
But it will try to start if you spray starting fluid in the intake with it unplugged.
This will keep you from flooding the engine with fuel until you find out why you have no spark.
Old Feb 14, 2011 | 06:50 PM
subford's Avatar
subford
Here is a diagram of the system:
Old Feb 14, 2011 | 07:41 PM
dustybumpers
maybe because my truck is a 94 is why it wouldn't start with the wrong mlps? good to know about the PCM/spark thing. thanks
Old Feb 14, 2011 | 08:00 PM
  #28
subford's Avatar
subford
I take it you are saying that it would not crank with the wrong MLPS.
That would have nothing to do with the spark.
Crank meaning starter engagement and not meaning that the engine is running.
Old Mar 17, 2011 | 06:16 PM
  #29
ratio411's Avatar
ratio411
It was a loose wire to the transmission.
Don't even know which.
I jiggled the wires checking the connections, then had someone crank the truck.
Fired right up. Drove it, and it shifted great.
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
tanker2008
Apr 13, 2010 11:25 PM
sddesigns
New Jersey Chapter
Mar 24, 2010 11:43 AM
A Bomb
Mar 8, 2010 04:15 PM
tanker2008
Illinois Chapter
Feb 7, 2010 01:14 PM
