duel vs single off set rim diff
Old Feb 14, 2011 | 09:23 AM
wuttrd's Avatar
wuttrd
i got a free rim and tire for a full size spair 35 12.50 17. ? is will a duel rim fit as a spair for a single axle, offset wise. thank you
Old Feb 14, 2011 | 03:53 PM
wuttrd's Avatar
wuttrd
rim off set
guess i will have to check it out when i get home to answer my own question . thought some body have a quick answer.
Old Feb 14, 2011 | 04:24 PM
big poppa's Avatar
big poppa
Not sure, you got 17 inch rims so I'm assuming you'd be ok, beings you have 17's already on there. As far as offset, don't know but for a spare, its better than nothing. Not sure if this helps any but you needed somebody to chime in, lol..
Old Feb 14, 2011 | 04:34 PM
Franko72's Avatar
Franko72
Molon Labe
If im understanding you correctly, you want to use a dually rim for a spare for your SRW truck?
I have never tried it, but in a pinch I guess you could bolt it up to get by for a short drive, (like the outside rear of a dually) but I dont think it would be good for the wheel bearings.
Old Feb 14, 2011 | 05:00 PM
megawatt00's Avatar
megawatt00
On the front it will rub unless you have the dually spacers. On the rear it may work but I would use it for very short distances. The dually is set up different than the SRW.
Old Feb 15, 2011 | 02:35 PM
wuttrd's Avatar
wuttrd
thank you
thanks for the replys. i will have to get a diffrent rim for the spare. thought i got off cheep.
Old Feb 15, 2011 | 03:29 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I would never put a stinking single wheel wheel on my truck.
I think the tire would stick out to much if you tried that.
Old Feb 15, 2011 | 04:24 PM
rbaker6336's Avatar
rbaker6336
I have thought about putting singles on the rear for winter.But that may be for next year
Old Feb 16, 2011 | 08:28 AM
miller_feed
Hey Ray. I heard of people running only the inside tire on a dually, but I would think that would look wierd. I had to take my outside tires off to run on the dyno at RRE-1. I couldn't wait to get the other wheels back on. lol
Old Feb 16, 2011 | 12:31 PM
rbaker6336's Avatar
rbaker6336
I intend to put wheels from a SRW on the rear (couldn't stand it with just inside wheel on).They will still look a bit funny but will pull better than the duals in snow.As soon as snow is over the duals go back on
wuttrd
Mar 4, 2011 02:35 PM
CropDusterMan
Feb 3, 2011 10:03 PM
REXHOUND
Jan 28, 2011 02:10 PM
shovelrocker
Jun 27, 2007 03:13 PM
toolebox1
Nov 9, 2004 09:09 PM
