93 Heat issues
Old Feb 14, 2011 | 08:49 AM
bluegrasmtns's Avatar
bluegrasmtns
93 Heat issues
What does the tiny little vacuum line going into the heater core box do? Mine is cut. I also have intermittent heat, which I think is due to a clogged up heater core. Doesn't steam up or leak coolant anywhere.
I know I've got to fix both problems, but I can't do either sitting here at work. I can post a question however...
Old Feb 14, 2011 | 09:04 AM
Duct Tape Racing's Avatar
Duct Tape Racing
mines like that, your blend door is probably stuck open letting cold air in as u drive versus being closed and reciculating the air inside. i just jammed mine closed for the time being
