Installing M5R2
Old Feb 13, 2011 | 10:58 PM
Ford_Six's Avatar
Ford_Six
Installing M5R2
Will an M5R2 with a small block pattern bolt up directly to a 300-6 where a 4speed once was? Will the clutch for the 4speed work with the M5R2's internal slave cylinder, or will i need to use a clutch for a later truck, or even a flywheel for a later truck?
Old Feb 14, 2011 | 11:01 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/2...-a-clutch.html Have a read here for some info. And the small block mazda trans will bolt up to the 300.
Old Feb 17, 2011 | 10:25 PM
Ford_Six's Avatar
Ford_Six
I know the trans will bolt up, I found the flywheel is the same as well so I just need the later clutch.
tndallas
Apr 17, 2015 07:00 PM
FlyCool5.0
Sep 30, 2013 10:12 PM
Chris Braun
Sep 15, 2012 06:37 AM
phoneman91
Apr 29, 2009 10:41 PM
