front axle ratio
Old Feb 13, 2011 | 10:21 PM
adworden's Avatar
adworden
front axle ratio
Is the front axle ratio the same as the rear? I've got a 91 Explorer XLT, 4X4 with manual locking hubs. The door sticker says the axle code is "45". I need to get some washers and locknuts for the wheel bearings, so I need the ratio.Thanks.
Old Feb 14, 2011 | 06:24 AM
SEAL1's Avatar
SEAL1
The axle ratio for the front and rear must be the same. If they were not you would know it the first time you put it in 4x4.
