1978 ignition diagram
Old Mar 11, 2003 | 05:35 PM
green78's Avatar
green78
Unhappy 1978 ignition diagram
I've been searching for a week trying to find out the wiring diagram for my F-150 Ranger. It's a '78, and the key(ignition went bad). I have toggle switches laying around, and since it's just a work truck, I don't need a key. Can anyone tell me how to wire up switches to get this thing to fire up? I've searched this and other websites to no avail.
I appreciate any and all help.
Thanks,
Shon
Old Mar 11, 2003 | 06:05 PM
Mil1ion's Avatar
Mil1ion
Well the resistance wire runs through the igintion switch, so how are you going to keep the coil from burning out?
To get the starter to work is easy.
Just put an push button switch inline to the S termi al of the solenoid.
MY suggestion: Replace the Ignition switch
Old Mar 11, 2003 | 07:50 PM
green78's Avatar
green78
I have checked with Ford, and a replacement key assembly is nearly $100. If I knew which colored wires were for what(accessories, etc....) I could hook up toggles to them, and then a push button switch on the ignition, couldn't I?
I'm not sure which wires go to what from the key assembly.
Thanks,
Shon
Old Mar 11, 2003 | 09:05 PM
masterbeavis's Avatar
masterbeavis
Try a wrecking yard, or your local parts house first.
Old Mar 11, 2003 | 10:36 PM
tejomakash's Avatar
tejomakash
Barry (BBB) has diagrams in his gallery for all duraspark setups. That will probably help some.
Old Mar 11, 2003 | 11:50 PM
Torque1st's Avatar
Torque1st
Posting Legend
Just pick up a key assy from the bone yard. They are plentiful. A locksmith can re-key the cylinder to your door locks or you can grab the door locks from the donor also.
Vegasw0lf
Aug 31, 2013 09:13 AM
Spaught
1947 and Older Ford Trucks
19
Apr 29, 2013 08:12 AM
kookookachew10
38
Jun 28, 2009 01:12 AM
78BamBam
Electrical Systems/Wiring
Aug 15, 2004 04:43 PM
