Has anyone tried these? I have the smoked recon lights and they arent bright at all.. I was thinking about switching them.. Would it be hard to take my smoked ones off and install these?
Ya they look alittle invovled.. But these look ten times better then those dinky recon lights that arent even bright.. Plus their like $10 cheaper lmao. I wish i woulda bought these instead of the recons.
I have them. They are brighter than factory but the yellow is a lighter shade. Also, I am going to put a toggle switch in so I can turn off the running lights in them for better strobe action when the headlights are on.
How difficult was it to wire these up?? The strobes that is.
I have the factory lights with recon led bulbs and well they stink. imo.
Pretty straight forward. Depends upon how many channels you want to split the lights on. Using just 1, only requires a signle wire run to the roof and then split it up to each lamp. Then power the controller from an upfitter/toggle and a ground.
