Fuel Problem?
Old Feb 14, 2011 | 07:11 AM
pooolguy's Avatar
pooolguy
Originally Posted by arctic y block
Damn this frosty sure is good. Hope ya get it figured out soon or hard telling what I may be telling ya to rip apart next.
Had a simular problem a couple weeks ago and did two things to correct it. One, the fuel line was getting a vapor lock. Make sure the line doesn't have any kind of hump in it, or a rise in it between the tank and the pump. Air gets trapped in the rise and causes the fuel pump to lose prime. I also had a loose coil wire causing intermittant firing problems. I don't know which corrected the problem, but it runs great now.
Old Feb 18, 2011 | 01:15 AM
CAL 250's Avatar
CAL 250
Well...we ended up springing for a new carb. The old one was leaking from every gasket and was a mess. We need it up and running quick so we had the shop put in a brand new one and wow...what a difference! I am all for keeping the truck as stock as possible, but with the new carb, it jumps to life on the first crank and runs so much better.
Thanks for all the advice. We will start working on the body & paint next.
