Out of no where today My truck is having a problem. When i parked it yesterday IT was running fine. Now all of a sudden when im shifting gears i have no power until it hits around 1800 RPM and boost kicks in? Any ideas at all?
If that is acting up/getting clogged the pcm may be getting erroneous data from the sensor and cause the ebpv to act up. This will probably affect your mpg and performance if you are getting bad readings from the ebps.
The only other thing I can think of is the ebpv is physically getting stuck while operating.
